  #13
Old 12-10-2017, 06:00 PM
michics's Avatar
michics michics is offline
Ha - I get the raspberries no matter what I do (deservedly so).
I was told it is a Richmond close ratio trans (5 speed) and no reason to not believe it. Without any actual verification, I can just say it works and gears 3-5 are pretty closely geared so it works pretty nice. I have decided to short shift the LS3 around 6k rpm for now so the gear changes do happen more often than with many other transmissions. I also do not know what rear end gear is in the car but I don't really care either. It's probably a 3.23 or 3.55 I reckon. I just get in and drive.
As far searching pointers.... I'd say buy the best, safest car you can find. I knew all the builders/installers of the systems of this car (cage, suspension, tuner, etc - all local, reputable names) as they were mostly all shops AT Sears Point, so that helped immensely.
There are a lot of what appears to be "deals" in the used race car world I think. Racing Junk (so aptly named) etc... I would be hesitant to buy sight unseen one of these.
This was intended to be a training car for me.... as my Camaro (when finished) will be a downright weapon of mass destruction. This just made too much sense for me and so far I am loving it.
You are on a good path - many PT guys have gravitated there or added a race car to their stable after figuring out what you are discussing here.
Good luck in your hunt. The hunt is very fun!
I not trying to insult you. Just offering a little knowledge on your r & p ratio.
You can figure this out by jacking the car put a mark on a tire and a mark on you driveshaft then rotate the tire one complete revolution while counting the revolutions of the driveshaft.
Thanks for your advice.
Mike
I'm old, gray hair, balding, and retired, and I'm still wrenching on cars. I thought wisdom came with old age.
70 Camaro, 406 sb, 6spd, 4:10 gear, BMR Suspension
