Are you talking about the under dash bracket that holds the vintage air unit? If so it works great. Very easy to install. I even modified one to work with my 67. If i remember correctly it mounts on the radio mount, and a cable bracket, and you drill a hole or two. Again very simple.
I used one in a customer car and added support because it seemed too flimsy without another support in addition to the hole drill deal. Worked out fine.
John Paige
lab-14.com
Didn’t you guys get the instructions with your bracket? I installed one of these a couple of years ago and it was pretty straightforward. I remember there was another bracket I had to buy also. I can dig out the instructions if anyone needs a copy.
I'm having he same issue on my 69 Camaro
Any help would be greatly appreciated
Thanks Don I have no idea what happened that small piece that goes to the ashtray piece. It’s probably in a box somewhere with all the other parts I can’t find for the car.
