Old 01-20-2018, 10:54 PM
DBasher's Avatar
DBasher DBasher is offline
How's this one coming along?
What he said, I’d love to see some progress on this one.
Old 09-15-2020, 11:39 AM
358Mustang 358Mustang is offline
Forgot about this place... Haha
Well I ended up building another car starting about 2018, the old track coupe is sitting in the corner of a shop collecting dust with the front end still cut off..
Finally got this engine together as of early 2020 and on the dyno, that was a big feat for me. Had a few issues , but nothing related to the engine .. Had a modified set of dyno headers that broke on multiple pulls so we had to pull those off and weld them up. The electric water pump wasnt sealing to the old yates belt drive so I had to rig up some spacers to sandwhich in place, and then the dry sump tank was puking a bunch of oil. Luckily I brought mine (which was a proper baffled tank) and that fixed the issue. The scavenge in the dyno tank has no sort of baffle or anything where it exits back into the tank so it must have just been making a tornado of oil going back into there with the 5 stage pump.. All in all that was a fun (stressful) day..
The aim with this car was to clean up a lot of fab work that I did on my last car (which started out as a project when I was 17 and no idea what I was doing, other than the fact that I had welders / plasma cutters near by ) , as well as keep it "street" legal
Rear end is a typical 3 link setup w/ panhard.
Front end I designed and built based off a cortex radial spindle.
Decided to go full standalone EFI sort of last minute, so I have been spending a lot of time (and cash ) trying to get that wired up and going.. This car will be running by the end of the year!!
The Following 2 Users Say Thank You to 358Mustang For This Useful Post:
DBasher (12-07-2022), WILWAXU (09-15-2020)
Old 09-15-2020, 11:42 AM
Sorry the pics are huge, Im a noob
Old 09-15-2020, 12:42 PM
Couple more. Decided to go DBW to compliment the ECU and its capabilities. using a unit from EFI hardware (uses a bosch DBW unit encased in a nice aluminum housing) The long term plan will be a 6 speed air shifted sequential but that is a little pricey so for now the 4 speed is going in. Plan on using a strain gage in the shifter for flat upshifts.
The Following User Says Thank You to 358Mustang For This Useful Post:
camcojb (09-15-2020)
Old 09-15-2020, 05:33 PM
Gitter dun! Thing is a bad ass!
The Following 2 Users Say Thank You to Flash68 For This Useful Post:
358Mustang (09-17-2020), camcojb (09-15-2020)
Old 09-17-2020, 01:57 PM
carbuff's Avatar
carbuff carbuff is offline
I like that DBW setup. Does the 'kit' you mentioned include a bracket or did you fab that yourself? Have you confirmed it runs through the full range of motion? Not that I've looked at many of those, but I like how this setup is done. Good job.
Old 09-17-2020, 03:40 PM
I'm trying !! Hoping to be running soon here ... But you know how it goes lol..
Thanks. It does not include a bracket or anything. I just made an ear weld off the intake , I needed to get it low as I could to clear my cowl air box. It's still close I need to space things a bit but it will work. Range of motion seems fine , I can actuate the unit manually and it seems good. Just need to set the min max's in the ecu once I get the electrical going. Curious to start playing around with different pedal maps too to make drivability nice
The real baller setup is the kinsler dbw motor , but I believe it's like 1800$ . This Bosch unit is very proven on OE cars so I don't believe I'll have an issue with it. Hell I think my 18' mustang has the same internals
