Old 01-27-2018, 03:53 PM
Default C7 control arm bushings
I have an aftermarket subframe with C7 upper and lower control arms and want to change out the bushings to polyurethane bushings. Problem is I can't find anyone that sells them for the C7 style control arms. Anyone have any info you can pass along will be appreciated.
Old 01-27-2018, 11:02 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Im sure you already saw RideTech has delrin ones which are a much better option than poly. No grease required, and last longer.
-Dale
SchwartzPerformance
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 01-28-2018, 08:35 AM
-Dale
I choked on the cost ($925)
Old 01-28-2018, 09:35 AM
JKnight JKnight is offline
I suppose the LG Motorsports MonoBall solution isn't going to be any more to your liking then. $$$
https://www.lgmotorsports.com/corvet...nsert-kit.html
The factory rubber bushings are looking pretty good!
Old 01-28-2018, 01:26 PM
Holy CRAP them are pricey, oh wait free install, where's my checkbook (lol) rubber it is!
Old 01-29-2018, 07:47 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Which aftermarket subframe did you choose to go with and why, if I may ask?
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 01-29-2018, 02:49 PM
ADY's Avatar
ADY ADY is online now
I used these energy bushing on my car that has an Art Morrison frame:
https://www.amazon.com/Energy-Suspen...RXD40KV0TCZ4Q7
I had the aFe Control PFADT Series bushing, but the c-clip retaining the bushing kept coming off, so the energy ones were the only economical option I found.
here's an article on a bunch of other options:
http://www.superchevy.com/how-to/cha...your-corvette/
-Adam
1968 Camaro SS
Old 02-23-2018, 09:06 PM
David Pozzi's Avatar
The Corvette LCA is adjustable with cam bolts. The mis-alignment created by adjusting doesn’t create much added binding with rubber, but that might be an issue with stiffer bushings.
http://www.PozziRacing.com
Old 02-24-2018, 08:01 AM
dhutton dhutton is offline
Curious if you have driven the car. GM engineering greatly exceeds what the aftermarket guys can bring to the table and the C7 is no slouch in the handling department. I would leave them stock as I have in the past....
Old 03-04-2018, 10:49 AM
Below is the perfect answer! Ditto, I say!
