Old 01-28-2018, 07:20 PM
garage_engineer's Avatar
garage_engineer garage_engineer is offline
I was able to make a ton of progress this weekend on the car. I was able to get the entire steering system out of the engine bay and then dropped the K-member. Here are a few pics:
Steering components out of the car:
I'm still working on getting the Pitman off of the steering box. My puller wasn't working even when I hit it with the impact gun so I'll have to check out some alternate methods. I will be sending the box out to be rebuilt as it has quite a bit of slop in it.
The rest of the steering linkage is definitely going to get replaced... it was looking pretty nasty. I don't think that tie rod has been adjusted in the last 30 years!
I then moved on to the K-member. First I popped the lower ball joints... I was able to get them loose with a few good whacks with the hammer. Again, found a ton of crud and dirt built up on the lower control arms. I think the front end might lose 20lbs in dirt alone!
Next, I put 2 jack stands under the K-member and took out the 6 bolts holding it up. In order to get it out from under the car though, I ended up using a chain to hook it up to my engine crane and lifted it just a bit to get it off of the jack stands so I could remove them.
Then, I lowered it down to the floor, removed the chains and dragged it out the side of the car.
Here it is outside the car with the springs and the sway bar:
I'm torn on how to proceed with the K-member. I'm on a budget, so my original plan was to clean it up and paint it. I was going to add some new bushings and ball joints to the control arms and re-use those as well. However, those tubular K-members and control arms sure are sweet! I'll have to do a bit of research here.
Next up is getting the brake booster out and keep labeling and removing the wiring harness. Little by little!
Old 01-29-2018, 05:42 AM
gofastwclass gofastwclass is offline
My opinion - stick to the budget and original plan which for me typically means fix what you have. Have some fun and upgrade as needed or finances allow.
If you are on a budget I would seriously consider your goals and make sure buying the replacement cross member or control arms is actually buying a planned and affordable performance upgrade. A good way to kill a budget and possibly project momentum is to start the "while I'm here I'll upgrade..." game. Ask the manufacturer(s) if the new parts are pretty stock replacements, are they lighter or do they actually improve performance in the manner you desire (drag racing vs. cornering), etc?
Just something to ponder. Remember disassembly is the easy part, good luck on the choice and project.
I build my own junk...
Old 01-29-2018, 05:38 PM
Good advice, thanks for the insight. It's definitely tempting to fall into the "while I'm at it" trap, but I'm also trying to be smart and replace things that are easier to get at while the engine is out. I'm going to make a few calls and go from there. Thanks again for the tips!
Old 02-02-2018, 05:20 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Nice build I HATE pulling the engine on my third gen and did it several times
I would think and A/M K-member would cut a bit of weight and add more room I'd do it - you are there
I'd suggest subframe connectors, they really do stiffen these cars up I didnt think it'd make much difference but boy did it
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 02-02-2018, 04:45 PM
If the aftermarket k-members don't offer better geometry, then stick with your factory one. The weight savings alone are not worth it. Your car is no where near that level of performance at this time. You'll be better served by buying better tires or upgrading the brakes with the money you would have spent on the k-member.
Old 02-02-2018, 09:39 PM
qnitro's Avatar
qnitro qnitro is offline
Im watching this one, seems like a good ride
Eat or be eat'n
Old 02-06-2018, 07:17 PM
I don't have a very exciting update this time around as I'm still working through removing everything from the engine bay, but here goes:
One of the biggest pains in the rear was getting the brake booster off the firewall. The 4 nuts holding the booster to the firewall are way up high underneath the dash and a royal pain to get to! For some reason, I'm always hesitant to take extra pieces off in order to get to a hard-to-reach fastener... I'll sit there and struggle with wrenches, ratchets, extensions and u-joints and in the end it usually ends up being faster just to bite the bullet and take off the couple other parts in the way. Anyone else do this too?
I ended up dropping the steering column in this case to get at 2 of the nuts and out she came. My master cylinder had some nasty residue on the bottom from some old fluid. I had flushed in some fresh DOT4 before my last track event but mustn't have done a good job cleaning it out. I want a firmer pedal, so I will doing some research to see which master cylinder will make sense to increase my pedal firmness.
Here are some other random parts I've been taking off and labeling: AC dryer, power steering "cooler", cruise control module and a few other hoses and lines. Slowly but surely getting there.
That's where I stand for right now. I'm shooting to have the engine bay cleaned out by this weekend so I can get started with the cleanup and prep for paint. Lots of work ahead of me too with cleaning up the wiring harness, painting the engine and lots of other odds and ends. I'm trying to keep the momentum up doing just a little bit every couple of days and chipping away at it little bit little. Gotta enjoy the journey!
