Old 02-22-2018, 08:46 PM
Goosesdad's Avatar
Here is my set up.
Just finished the installation, it's a pretty nice piece. I used Lokar cables, they are also pretty sweet. Smooth inner liner makes for a slick cable pull even with some pretty tight bends.
This will all be covered with the center console and the rear deck area. EStopp is a little loud to be mounted inside but since this will all be covered with the center console and rear deck, most of the sound should be mitigated. The button is pretty nice and overall a pretty clean set up.
Mounted it on some 16gauge with the nuts welded underneath.
If you buy the Lokar cables, you won't need the EStopp splitter (the machined Al block) as the Lokar kit comes with a pretty nice splitter. The Lokar set up is actually a little tidier.
Have a great day!
John
My Build Thread:
Old 02-24-2018, 05:48 AM
cpd004's Avatar
cpd004 cpd004 is offline
Nice! Which dimple die tool are you using?
1971 Firebird
2017 SS
Old 02-25-2018, 09:41 AM
Goosesdad's Avatar
1 3/4" from JBugs
Have a great day!
John
My Build Thread:
Old 05-23-2018, 06:41 PM
mklinger mklinger is offline
Default Another Alternative Installation Idea
Thought I would add to this thread since some good ideas were shared. Here is what I came up with for installation in a 2nd gen Firebird. Some where between not having enough room and enough cable was this idea. Works great and looks great. Tucked out of sight.
The Following User Says Thank You to mklinger For This Useful Post:
cpd004 (05-24-2018)
Old 05-23-2018, 08:25 PM
It looks great, nice job!
Old 05-24-2018, 07:17 AM
Goosesdad's Avatar
Well done!
Have a great day!
John
My Build Thread:
Old 05-24-2018, 11:13 AM
joeko23 joeko23 is offline
I bought this kit it has everything including that bracket that estopp sells separately all within the box. It's a nice self contained unit. I'm mounting mine right under the package tray (in the trunk floor) in my 69 Camaro. It's basically the same unit Speedway sells but way cheaper
https://www.ebay.com/itm/Push-Button...gAAOSwhEla-vd4
Old 06-02-2018, 10:07 PM
Dr. Jekyll Dr. Jekyll is offline
Wow what a really great set up, thanks for sharing!
