Old 03-09-2018, 09:23 AM
SSLance's Avatar
SSLance SSLance is offline
I've got some updated outside pics if anyone is interested?
The builder finished "their version" of the final grade a couple of days ago. It shows pretty much what the lot will lay out like. We have narrowed the landscape contractors down to two and are tweaking the final plans now. Whichever one we chose will be able to hit the ground running right after we close April 12th.
The front yard and driveway...
Area directly behind the RV Garage...
I'm having 1/2" screened rock put down behind and beside the RV garage for parking, turn around and such. The car trailer will be tucked in between the shop and fence when not in use.
The outside AC condensor for the shop will sit along the back wall between the pool heater and the garage door and a Pool Equipment wall will hide the equipment so it can't be seen from the pool area.
Future plans call for a firepit area on this side of the pool from the house. For now we are putting a BBQ island over on the side of the travertine deck closest to the fence.
I've chosen a company to finish the floors in shop and house garage, this is the process they'll use.
– Grind and Seal
-perform 30 grit diamond grind in order to expose salt and pepper aggregate
-patch minor cracks, joints and spalls using a cementitious repair mortar
-perform 80 grit finish grind
-apply clear polyaspartic sealer at approx. 4-6 mils thickness
The Polyaspartic is a clear epoxy that will protect the smoothed out concrete will making it easy to clean and also easy to repair if necessary. They plan to start the day we close as well.
Not much else has happened inside the shop in a while. Waiting on electric meter to be set so they can finish the install of the third door opener and tidy up a few other loose ends. Then one final touch up paint and it's ready.
The house is close also, carpet is down, final electric and plumb done, working on prepping for final paint and appliances. And odds and ends...LOTS of odds and ends...
Lance
Old 03-09-2018, 09:27 AM
Hey! Get some water in that pool!
I'll be down Friday the 16th -- planning to hit GoodGuys on Saturday (maybe even Friday...)
WOW --- that yard sure looks different than when I saw it last time!!
Old 03-09-2018, 10:45 AM
SSLance's Avatar
They will put the turbo heads in the pool next Monday...then it'll be ready for the final interior finish, then water.
So, you'll finally get to meet Barney on Sat, cool. I'm taking the RV and camping at GGs all weekend, I expect you to look me up while there. I'll have my extra helmet with me just in case...
Lance
Old 03-09-2018, 02:04 PM
jarhead's Avatar
jarhead jarhead is offline
Beautiful!
And I LOVE that driveway, so much nicer than concrete!
Joe
joe
Semper Fi
My 68 Torino
Old 03-09-2018, 02:36 PM
SSLance's Avatar
Thanks Joe!
I like the looks of the pavers as well. Not sure about how the upkeep on it will go though. Trying to decide if I should attempt to seal them or just let them be? Will also need to be a bit more careful with my "racer friends" and letting them park their leaky cars on it.
Lance
Old 03-09-2018, 06:47 PM
Sieg's Avatar
Sieg Sieg is offline
Can you not pull the oil spotted pavers and install new ones? Keep a few new ones stages out in the weather so they naturally age with the driveway pavers.
Old 03-09-2018, 08:32 PM
SSLance's Avatar
Not a clue Sieg, I'm used to just hitting the stains on my concrete drives with brake cleaner and a pressure washer...
Lance
Old 03-10-2018, 11:44 AM
That's a hell of a nice set up. I'll make sure my wife doesn't see the photos of that pool.
Old 03-10-2018, 09:31 PM
SSLance's Avatar
Thanks! And how do you think I got the big shop I wanted?
Lance
Old 03-11-2018, 08:26 AM
Wow that looks great!
The Following User Says Thank You to Flash68 For This Useful Post:
Lenie (03-15-2018)
