Old 03-09-2018, 11:43 AM
dmc69's Avatar
dmc69 dmc69 is offline
Nice Work! Always good to see a nice garage build!
DMC69- 69 SS350-LS3/6speed
Old 03-09-2018, 12:56 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Very nice work so far,keep updates coming
Old 05-20-2018, 04:10 PM
Gmachine1911's Avatar
I agree...I love seeing the pro builds but I've gleaned equally as much from many of the garage builds on here. I like where you're headed with this one; nice work and keep the updates coming!
Old 05-23-2018, 07:22 PM
Nice work! Your doing a great job. I wish I had gone with the adjustable coil overs in the front. Keep the updates coming I’m enjoying them.
Old 05-24-2018, 07:31 AM
TorqStorm's Avatar
TorqStorm TorqStorm is offline
Keep up the hard work. A little bit everyday
Torqstorm
[SIGPIC][/SIGPIC]
www.torqstorm.com
Old 06-12-2018, 08:01 AM
DWC's Avatar
DWC DWC is offline
Update-
After letting the urethane/butyl in the window channels sit and dry out, I was able to get it off surprisingly easy with just a wire wheel. Happy about that.
I have 95% of the paint removed from the body shell. Just a few nooks and crannies left to get to.
I've never worked with body filler before...oh what a joy. It looks a hell of a lot easier on Youtube... I'm still getting a feel for how much hardener is needed when it's 85* out with 80% humidity. That stuff turns over *fast* with too much hardener. Also, trying to get a feel for how/how much to apply so I don't create more sanding than needed and/or dull body lines.
There are a few old rust repairs on the doors that need attention. I tackled the door with only one bad spot so far and I think it turned out ok. In the last photo here, I was about 90% done. I was able to blend it a bit better before I primed it.
Daniel
The Following User Says Thank You to DWC For This Useful Post:
gmc427 (03-31-2019)
Old 06-12-2018, 07:06 PM
Nothing dull about that body line! nice job.
Old 06-13-2018, 04:45 AM
DWC's Avatar
DWC DWC is offline
Thanks Wayne. That door just has etch primer on the bare metal. I haven't started filler work on it yet. It's a decent door to start with, but if you look close, the body line towards the bottom of the photo needs some help.
Daniel
