Old 03-12-2018, 12:02 PM
Originally Posted by rustomatic View Post
What's the prognosis on the clutch? The pedal clearly stopped playing an active role in the game . . .
If it makes you feel better, my truck's water pump gave up yesterday (no towing was involved). It'll cost me nearly $60.00 to fix. Dang it.
Not sure yet. But I wanna maybe try to make Sonoma this weekend. We'll see.
Glad you made it home at least before the water pump failed.
Originally Posted by DBasher View Post
Was the clutch pedal to the floor with zero resistance or was pressure noticeable and just won’t engage a gear?
Hopefully it’s an easy cylinder swap or TOB....if not, it may be time to swap the SB2 and dog box.
After no issues 1st session it just wouldn't shift from 5 to 4 going into T1. Or any gear after that - while running - for that matter.
7 total laps for the day....
Hopefully something minor.... as I sat on the shoulder of T2 waiting for the tow I did think to myself.... "you do have a trans not doing anything right now..."
Old 03-12-2018, 12:30 PM
fleet's Avatar
fleet fleet is offline
...and thankfully you have a ‘crack’ staff already in place to fix your muttmobile.
Old 03-12-2018, 06:49 PM
gnx7's Avatar
gnx7 gnx7 is offline
Mark I am guessing you ran your Monster RX7 there?
I had another red RX-7 widebody with 18x12's at all corners, JRZ triples, 2470lbs wet with detuned 438 stroker LS7 (stock LS3 heads and made only 530rwhp to try to meet power/weight rules), GForce GSR dogbox, and 3.27 gears in a Cobra IRS 8.8" diff with custom axles running the RX-7 suspension out back. It had an ARE dry sump system. My first time at Laguna ever I ran a 1:35.5 with it... my buddy who built the car ran a 1:33 flat and said there was a lot more left. Also broke the GSR dogbox by not fully engaging reverse and sheared the teeth off it... We ended up tearing down the box at the track.... cleaned it up... removed reverse and ran it another couple sessions.
Sadly after running the 1:35.5 a couple laps later the bolt from the dry sump pump walked off... allowed the pulley to move... which then made the belt fall off.... so I seized the motor. That was an expensive day! Cameron Rogers now campaigns the car in TTU I believe. It's gray now....
Old 03-14-2018, 11:09 AM
Wow! That thing is an evil little bastard. Must be a hoot to scream around in.
Low to mid 1:30's ... that is haulin the mail at Laguna. And I am sure all of my "fast" friends who think they are fast could beat that. They know who they are.
Old 03-16-2018, 02:43 PM
Old 03-16-2018, 08:53 PM
Sieg's Avatar
Sieg Sieg is offline
I had absolutely no idea trailering was so hard on a race car
Old 03-16-2018, 09:37 PM
a Tilton 5.5 inch triple disc is apparently not a pro touring clutch.
Old 03-17-2018, 08:31 PM
One mustn't fail to mention the smoky burnout (going uphill) on the trailer--that's pro-trailering. Clutches love this.
Old 03-18-2018, 12:41 PM
DBasher's Avatar
DBasher DBasher is offline
Both those RX7’s sound like wicked little cars, nice job Mark.
Dave, you’re ruining the pedigree of that car...
Old 03-18-2018, 01:32 PM
I just want to make sure you know they sell replacement ckutches. You don’t need to rebuild the WHOLE car.
