  #14
Old 03-28-2018, 09:53 AM
gerno's Avatar
gerno gerno is offline
Ron - another question about the structure, this time the cage.
Based on pics of other builds it seems typically people use 1 piece front pillars that extend from either the main rear hoop or the roof hoop to the floor. In this build the front pillar is a short piece attaching the roof hoop and dash bar. I also notice the dash bar isn't bent but instead welded together. Without having any real knowledge of what works best I always assumed it was better to bend the steel rather than weld it together. This build seems to prove my assumptions wrong and in general this looks a bit easier than bending in tight spots. Is there any difference or benefit in strength when bending vs welding a joint?
