Old 03-29-2018, 02:27 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Originally Posted by classiccamaro View Post
Jeff...... Looks like you are moving right along, and doing beautiful work as always! What oil pan do you use with your DSE/LS set-up? I'm ready to launch my next build and I'm getting all my "stuff" put together. I know there are a few choices that will work, just thought I would ask....
Thanks, Dave
Hello Dave,My last car had an F body oil pan but I also had DSE mounts that set back 1.5".My LS9 has a corvette pan but I have not installed it yet to see how it works.You are running an LSA this time aren't you?Have you talked with DSE about it yet,they are very helpful.
The Following User Says Thank You to tubbed69 For This Useful Post:
DKz Garage (03-29-2018)
Old 03-29-2018, 05:22 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Jeff, Thanks for the input, on my current build (70 Camaro) I am running all DSE equipment, including their frame/engine mounts, which on a second gen, move the motor back 1". The stock pan on the LSA wont work. DSE does list the "F-body" pan as a part that will work. I was just curious if I was missing some advantage to running a MAST or Holley piece?? I can get the GM stuff super cheap through a friend at a dealership...so that is probably the direction I'm heading.
Keep up the good work!
Dave
Old 03-29-2018, 06:23 PM
tubbed69's Avatar
Dave
Your welcome Dave I have run the F body pan on 6 or 7 so far,good luck and keep updates coming
Old 05-18-2018, 07:46 PM
tubbed69's Avatar
Spent some time welding several holes up in the core support and inner fenders and put a new firewall in, this is the new firewall that Dynacorn is now making, got it and other parts in black primer for now.
Old 05-18-2018, 07:52 PM
tubbed69's Avatar
Picked up a couple LS9 engines, also got a new Mcleod RST clutch and Quicktime Bellhousing.Got my engine mounted in car for now to start trying to figure all this plumbing out,first time working with the supercharged engines.Putting the other engine and trans in a 1971 Chevelle.
Old 05-18-2018, 08:59 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Firewall looks great. I didn't know about them from Dynacorn...thanks!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 05-18-2018, 11:32 PM
jarhead's Avatar
jarhead jarhead is offline
looking good Jeff!
Glad to see I'm not the only one using a TKO
joe
Semper Fi
My 68 Torino
Old 05-19-2018, 08:47 AM
Musclerodz's Avatar
They have had that piece out for awhile, first time I have seen anyone use it. How do you like it? Is it an overlay or cust the old out and weld this one in?
Mike Redpath
Musclerodz & Customz
facebook page
Old 05-19-2018, 12:06 PM
tubbed69's Avatar
I had seen it advertised also but never had seen it so thought I would try it,I cut my firewall out and welded it in,I did just weld it over the upper cowl/firewall.I like it really well,still need to drill for my ac/heater hoses and wiring harness.
Old 05-19-2018, 12:19 PM
garickman garickman is offline
It's a JCG Restorations part. Chris was hand making these for his first gen customer builds and then he sold the design to Dynacorn to start stamping them. If you go to the JCG Restorations website, they actually sell a billet plate with the A/C ports that fits right in the rectangle stamping on the passenger side.
Here is a 7 year old thread, post #206 shows the first firewall he ever made along with the billet A/C plate.
https://lateral-g.net/forums/showthre...=30020&page=21
Greg
