I noticed that a lot of your engine packages state that you use are using a cable operated throttle body.
What drives the decision to use DBW or cable? Availability of throttle body size for power considerations? User preference? Other?
Howdy !
Actually ... I need to change that in our new catalog ... because we offer both DBW-Drive by Wire and traditional cable operated throttle bodies. It is user preference (or needs). I find we sell about half cable operated & half DBW. Just depends on what the end user needs.
For the DBW throttle bodies we use:
* Stock GM LS3 92mm version for 625HP & lower
* Nick Williams 102mm version 700HP & up
For the Cable operated throttle bodies we use:
* Holley 90mm for for 625HP & lower
* Holley 95mm for for 675HP & lower
* Holley 105mm for for 700HP & up
For Greg's car, the electronic "no-lift" sequential shift controller needs a DBW throttle body to work correctly. On upshifts, the electronic "no-lift" sequential shift controller kills the power for a fraction of a second, to make the shift smooth. But the throttle stays wide open (as long as the driver has the throttle pedal wide open.) On downshifts, the electronic "no-lift" sequential shift controller needs to "blip" the throttle to make the downshift happen smoothly, so a DBW throttle body is needed.
If we had not ran the sequential shift transmission, we would have ran a cable operated throttle body.
Hope this insight helps.
__________________ Ron Sutton Race Technology
The Following User Says Thank You to Ron Sutton For This Useful Post:
Saw this in Monkton Maryland while working, figured Greg was far enough into the project, and the billing cycle. That this sign was probably feeling applicable. LOL
