Old 07-23-2018, 05:22 PM
Gmachine1911's Avatar
Just a quick update...been working a lot at my J.O.B. but reached a huge milestone last week. What started out as simply getting the gauges to light up and check function turned into "well let's see if the engine turn over" which then turned into "let's puts some fuel in the tank and see if it'll start!" I'm happy to report that the only issue was a fuel leak at an AN hardline fitting that required some attention. Once that was fixed, the motor fired right up, open headers and all!
The Following User Says Thank You to Gmachine1911 For This Useful Post:
syborg tt (12-29-2018)
Old 07-23-2018, 05:32 PM
So here's the DD VHX gauges all lit up. This was some of the best money I've spent so far. Super easy to install. Super easy to wire up and absolutely brilliant quality. The pictures really don't do the clarity justice...
Old 07-24-2018, 08:56 PM
I love them they look sweet!
Old 07-24-2018, 10:42 PM
67_camaroRS's Avatar
67_camaroRS 67_camaroRS is offline
That's a nice steering wheel, is that suede? Was it easy to install?
1967 Camaro RS
1969 Camaro coupe
Old 07-25-2018, 04:19 AM
Yeah, it's black suede with silver stitching. Install was easy, too. Never had a suede steering wheel before but it feels good in the hands!
Old 08-08-2018, 07:49 PM
So not really any huge strides to report, just been going thru doing some detail work. Got the heat/AC lines plumbed up. Everything's done on the engine side, now I just need to get the inside lines done to the evaporator unit.
I got the rear brake lines wrapped up and some detail items on the interior. I installed a Retrosound Long Beach stereo and remote mounted the body of the radio under the rear package tray to conserve space in the dash. It's a nice piece, looks pretty much factory and has a huge amount of features such as Bluetooth, hands free phone calls thru the sound system, Sirius XM, USB ports, etc. Basically the only thing in the dash is the radio face and knobs but you can't tell the difference by looking at it.
I also got my Borla mufflers, extra V-band clamps and odds and ends and have it scheduled for the exhaust shop next week but, until then, here it is sitting on the ground again...
Old 08-08-2018, 07:55 PM
Here's a shot with the finished heater/AC lines...gotta tuck a few wires away and wire up the trinary switch. Once I get the exhaust done where I can run it without scaring the neighbors, I'll make sure there's no leaks, etc. and then get the front sheet metal reinstalled.
Old 07-25-2018, 04:16 AM
Thank You!
