Old 08-08-2018, 08:09 PM
Gmachine1911's Avatar
Truck-Lites on dim...
The Following User Says Thank You to Gmachine1911 For This Useful Post:
syborg tt (12-29-2018)
Old 08-09-2018, 02:32 AM
slimjim's Avatar
slimjim slimjim is offline
Trucklite actually make a matching 4.5" fog light (80275), They're only really advertised for Harleys, I'm yet to make mine fit but it'll look great when they do.
NC
streamline 68 camaro
Build Thread here
The Following User Says Thank You to slimjim For This Useful Post:
Old 08-18-2018, 05:20 AM
Had the car loaded up and taken to my exhaust guy yesterday. Got some 3" stainless bent up to go along with the Borla mufflers...
Old 08-18-2018, 05:23 AM
Old 08-18-2018, 05:26 AM
When I get it home, I'll remove it and clean up the welds.
I'm curious, what's anybody else doing to keep the emergency brake cables from rubbing on the floor pan? At the least I'm gonna have to put some type of sleeve over them but I'd love to see pics of what others have done...
Old 08-18-2018, 05:41 AM
He nailed it on the exhaust hangers for the mufflers. I had provided some isolators for the hangers but he ended up using some S10 isolators that had metal inserts so they won't tear or break as quickly over time. I'm still waiting on my driveshaft so they mocked one up from 3" exhaust tubing.
Despite all my hopes and prayers, it appears I'm gonna have to do some surgery on the trunk pan corners to create enough room for the tail pipes to clear
The one time I should've cut "cut corners" on this build...anyway, now I get to do it after the fact.
Old 09-17-2018, 05:52 PM
Got my front seat belts today...normally, the "Schroth Racing" emblem would be in yellow, however, I had them cut it off and sew on the black/silver emblem in its place. They went above and beyond on the customer service side to get me the belts I wanted in the configuration I wanted.
Old 10-06-2018, 08:36 AM
DT69Cam DT69Cam is offline
Beautiful car!! Can I ask a question about your exhaust though ? I have a similar set-up with my mufflers, do you think the driveshaft will hit the drivers side muffler ?? Thanks.
69 Camaro Convertible (LS3/TKO in the works)
