  #27
Old 08-16-2018, 03:55 PM
Merritt5 Merritt5 is offline
Been awhile since my last update, so here we go.
Got the upper control arm bracket measured out and made, tried to get anywhere from 0 to 15* of adjustment.
Ordered new fuel tank (old one was rusted and leaking) and weight jackers for the rear.
Got the brackets and weight jackers welded up and in the car!
Luckily, the weight jackers are accessible and hidden.
Got everything assembled and back into the car...(I know, I should have painted the rear while it was out)
Couple issues I did run into;
- Panhard bar hit the roll bar (thought it was good, but nope). No problem though, I just moved the roll bar forward an inch.
- The upper link clamp rotated on a test drive, I ended up welding the bottom half of the clamp to the rear.
After I fixed all that, I got the car out and ran an autocross
Car felt much better. Need to play around with some adjustments and see what the car likes.
Overall, I'm happy at the moment. Finally getting the car out and beating on it was a blast.
1993 Fox Body...its in the works
https://lateral-g.net/forums/showthread.php4?t=54321
1972 Nova...OUT OF THE BARN!!!!!
IG:@kdmerritt5 for more
The Following User Says Thank You to Merritt5 For This Useful Post:
jarhead (08-17-2018)
