Old 08-30-2018, 09:05 AM
Yelcamino's Avatar
Yelcamino Yelcamino is offline
Originally Posted by Che70velle View Post
Glad to see your back at it Herb. The car is beautiful.
Thanks Scott!
Herb
1966 El Camino LS408/T56Magnum
1966 Chevelle 509/T56Magnum
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 08-30-2018, 10:00 AM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Originally Posted by Yelcamino View Post
Thanks Ric! I didn't level the scales beforehand and the hood is on the roof, so I'm sure that skewed the results. At least I have a place to start so as I add things I can try to keep it balanced.
And yes, I'm building a new floor because I want to run a belly pan and keep everything above the bottom of the frame.
Just remembered, the last time I scaled my car I had shock simulators to set ride height and when I put the shocks in and weighed it again, everything was different.
Strange thing, the ride height was the same! Go figure. Great job!
Sent from my SM-J320V using Tapatalk
Ric
Old 08-30-2018, 10:46 AM
You're killin' it again Herb!!
Nice work and will be a great project! Hurry up so I can see it finished!
Old 08-31-2018, 06:40 PM
Yelcamino's Avatar
Originally Posted by Peter McMahon View Post
Ah, I see. I thought all the pick up points for suspension were forward of the horizontal rails and the rails were only for rear body support and bumper support Either way it’s an awesome car and you got a big set on you chopping out that floor! I would have to be hammered to get the guts to do that! Keep the updates coming
Thanks... and don't tell anybody, but:
10095 by Yelcamino, on Flickr
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 08-31-2018, 06:42 PM
Yelcamino's Avatar
Thanks Greg! I'm making some changes to the El Camino this coming week and once that's done I'll be burning the midnight oil on the Chevelle!
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 08-31-2018, 06:45 PM
Yelcamino's Avatar
I have all-thread with shock eyelets on each corner to simulate ride height, so I'm sure once everything is in place it will be totally different.
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 09-15-2018, 04:25 AM
Yelcamino's Avatar
In an effort to keep this project moving forward, I set the trans and bellhousing in place.
10112 by Yelcamino, on Flickr
This enabled me to make sure I had the engine where it needed to be, specifically to be sure the return line for the power steering reservoir cleared the shock mount.
10113 by Yelcamino, on Flickr
To help figure out driveline angles, I cut 10-3/8” off of a damaged driveshaft from the El Camino and welded it together for mock up. In case you're wondering, the El Camino and Chevelle used the same length driveshafts, so that means the Chevelle's engine is 10-3/8" back from stock location.
10114 by Yelcamino, on Flickr
10115 by Yelcamino, on Flickr
With an actual driveshaft in place, I now see the rear hoop needs to be raised… so there’s my next project within a project!
10116 by Yelcamino, on Flickr
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 09-15-2018, 05:37 AM
That's a crazy amount of set back, Herb! Keep up the good work!
Old 09-15-2018, 06:23 PM
It looks good Herb, that setback should make a nice difference.
Old 09-16-2018, 12:59 PM
Yelcamino's Avatar
Thanks guys! I hope all this work is worth in the end!
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
