Old 09-19-2018, 12:13 PM
Oleyellar Oleyellar is offline
Not enough info on the car to know for sure, but, some ideas....proportioning valve setting, or is there one? Do you have one with a switch that could have shifted? Do you know for sure the front brakes are functioning? I had a situation where the master cylinder was not allowing full pressure to the front calipers. There fronts would show some marks on the rotors and would clamp when turned by hand, but were of no use while driving.....Is your Willwood master one of the recalled ones? Are the front calipers sized properly for the weight of the car?
Old 09-20-2018, 10:21 AM
RidiCat69 RidiCat69 is offline
Originally Posted by Oleyellar View Post
....proportioning valve setting, or is there one? Do you have one with a switch that could have shifted? ...
This is very real. If the prop valve/combination valve has a safety switch and you bleed the system with no pressure on one side, that side can close off. The combination block thinks there's a leak and is trying to save one of the circuits. If you do have one like this, the plug in the middle of the valve can be removed and you can visually inspect to see if its tripped. A tool is actually sold to hold this pin in place while bleeding an empty system.
You said you had good pressure when you put the gauges on the calipers. Remember what that pressure was? Was it equal on front and rear?
What is the pedal ratio? If you're coming from a manual drum or a power disc the input pressure wouldn't need to be as high as the manual disc requires.
Here's my favorite one that I've see converting from a manual drum car to manual disc. Firewall deflection. It doesn't matter how hard you push on the pedal if the firewall is absorbing all the pressure.
Binding push rod into the master can be something to look for too, or how about the bushing between the pedal lug and the pushrod, or the bushings for the pedal itself?
Ryan
69 Cougar
Old 09-20-2018, 11:28 AM
jlwdvm jlwdvm is offline
Master is in the manual pedal hole and the bushings for the pedal and clutch are new. I have an adjustable Wilwood proportioning valve and I can get fronts and/or rears to lock up if the brakes are warm and I really slam on it.
I can't remember the exact numbers we were seeing, but they were fine for the system.
I guess my feeling with the system at this time is that when I am driving around town I seem to have to think ahead to stop. A panic stop in traffic might be a little iffy.
Old 09-20-2018, 11:40 AM
Default Heat'em up, bed'm good.......
Looks to me like you have everything working properly for a manual brake setup. Time to start doing squats, and get those thighs toned up!
Old 09-20-2018, 01:24 PM
Some don't like when I say it, but manual brakes on the street aren't ideal. They are made for the track.
Old 09-20-2018, 01:59 PM
gerno's Avatar
gerno gerno is offline
I have a 7/8" MC too and when first installed my brakes were not working. Issue was the pedal rod adjustment. I didn't have the rod long enough to account for the long pedal travel. I lengthened the rod and had amazing brakes. I would check that first.
Old 09-20-2018, 07:01 PM
I assume you have manual brakes too?
Old 09-21-2018, 10:58 AM
SSLance's Avatar
SSLance SSLance is offline
Yep... I don't even like them for autocross either. They take way too long to react for my taste.
Lance
