Old 09-20-2018, 11:28 AM
jlwdvm jlwdvm is offline
Master is in the manual pedal hole and the bushings for the pedal and clutch are new. I have an adjustable Wilwood proportioning valve and I can get fronts and/or rears to lock up if the brakes are warm and I really slam on it.
I can't remember the exact numbers we were seeing, but they were fine for the system.
I guess my feeling with the system at this time is that when I am driving around town I seem to have to think ahead to stop. A panic stop in traffic might be a little iffy.
Old 09-20-2018, 11:40 AM
Oleyellar Oleyellar is offline
Default Heat'em up, bed'm good.......
Looks to me like you have everything working properly for a manual brake setup. Time to start doing squats, and get those thighs toned up!
Old 09-20-2018, 01:24 PM
Some don't like when I say it, but manual brakes on the street aren't ideal. They are made for the track.
Old 09-20-2018, 01:59 PM
gerno's Avatar
gerno gerno is offline
I have a 7/8" MC too and when first installed my brakes were not working. Issue was the pedal rod adjustment. I didn't have the rod long enough to account for the long pedal travel. I lengthened the rod and had amazing brakes. I would check that first.
Old 09-20-2018, 07:01 PM
I assume you have manual brakes too?
Old 09-20-2018, 10:20 PM
gerno's Avatar
Yes they are manual
Old 09-21-2018, 05:36 AM
The pedal rod nearly bottoms out on the brake switch mounting area. I would presume it is long enough since I can't adjust it out any further.
Old 09-21-2018, 10:58 AM
SSLance's Avatar
SSLance SSLance is offline
Yep... I don't even like them for autocross either. They take way too long to react for my taste.
Lance
