Old 10-26-2018, 04:33 PM
Amazing write up! Thanks. They looks great, always amazing work.
The Following User Says Thank You to waynieZ For This Useful Post:
Goosesdad (10-29-2018)
Old 10-29-2018, 08:25 PM
Goosesdad's Avatar
My thinking: There really isn't a good/solid/safe place to put jack stands on the narrowed rear rail (after install of DSE 4link) because the lower link bar is below the frame rail, it’s just tight and cumbersome. Also, given that the front subframe is wider than most jack stand posts making it a little unstable/insecure....and that both of these locations are not ideal for the lift pads such that there is low risk of the car shifting/sliding in the front and the same clearance issues exist in the rear....and that you really need to raise the car first, before being able to put it on the lift, I built these points to solve the above.
In the rear, this point is affixed to the lower 4 link mount that I made. This whole area is tied to the rear frame rail which is/will be basically attached to the rear roll bar down tube.
In the front this lifting point is placed on top of 1/8” thick pad that will be connected to the front down tube of the roll bar.
I will add a lifting point for the floor jack which will lift from the new trans x-member which is connected to the roll cage.
Built them this way so there was effectively a couple of “feet” that will dig into the lift pads to further anchor the car in place. Also, these little feet serve to help keep the car from slipping on the jack stands. Also, these front and rear points will provide for the car to be perfectly level on lift.
Agreed, all of this is a bit of overkill but it only added about 7lbs and I think it will make life easier overall.
Size:  136.2 KBName:  o4.jpg
Interested in your thoughts.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
syborg tt (12-28-2020)
Old 10-29-2018, 08:38 PM
Not a bad idea!
Old 10-31-2018, 07:04 PM
Great idea! I run into this issue when lifting my TA for the exact reasons you mentioned.
Old 11-03-2018, 12:29 PM
Nice
Old 12-25-2018, 04:52 PM
kevin_l's Avatar
kevin_l kevin_l is offline
Fantastic metal work and planning. Some how I over looked this thread. You're attention to detail is amazing. Keep up the good work.
