Old 11-06-2018, 03:44 PM
GEARBOXGARAGE's Avatar
GEARBOXGARAGE GEARBOXGARAGE is offline
Called StopTech today and they knew nothing of this?? I did get some part numbers for a 2011 Corvette that I think would work on the SpeedTech ATS Spindle and Full floater hub assemblies. Not sure how much of a difference the piston size is from the standard big brake kits to Ron's optimized package. Blake, can you shed a little more light on this?
-MIKE
Old 11-07-2018, 06:27 AM
dontlifttoshift's Avatar
If you are going with manual brakes, you are going to want the big piston front calipers.
Donny
The Following User Says Thank You to dontlifttoshift For This Useful Post:
GEARBOXGARAGE (11-08-2018)
