Old 11-25-2018, 01:34 PM
Originally Posted by Gmachine1911 View Post
Hey Randy, thanks for the response. I unhooked the fuel line at the rails (no fuel present) and cycled the key 5 times. Each time the fuel pump cycled but no fuel ever showed up. Is it possible that I inadvertently transposed the wire connections?
Are you using a vsppoworx tank with the returnless system? I read for the first startup you need almost a half tank to get it primed up
Old 11-25-2018, 01:45 PM
Gmachine1911's Avatar
No, I've got a Tanks, Inc. fuel injection tank with a Vette style regulator. The return line is only about 12" long. When I was checking things over last night, there was no fuel present at the regulator either. Thanks!
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
Old 11-25-2018, 02:10 PM
I have hooked my tanks inc fuel pump up backwards doing some bench testing and it sounds close enough to normal that I wouldn’t have been able to tell the difference. Very possible you hooked the wires up backwards.
Is there enough fuel in it?
Old 11-25-2018, 02:28 PM
Yeah, that's good to hear. I'm thinking that's gotta be the issue. It's got 1/4 tank of fuel so should be more than enough. I'm gonna take the gas back out and drop the tank to check the wires. It's gotta be something simple. I appreciate the feedback...it's a huge help!
Shane
#theanchorholds
Old 11-25-2018, 06:22 PM
Alrighty then, just in case there was any question about whether you're in tank fuel pump will supply fuel if wired backwards...it won't! lol it's those little things that make the difference!
Shane
#theanchorholds
The Following User Says Thank You to Gmachine1911 For This Useful Post:
syborg tt (12-29-2018)
Old 11-25-2018, 06:26 PM
Awesome that you found it ...Loki g forward to the video 👏
Old 12-03-2018, 05:58 PM
So, while my Camaro's off getting the front clip reinstalled, alignment done and tail pipes made, I talked my Dad into putting a FiTech system on his 79 Z28. Fun fact about this car is that a neighbor up the street owned it for about 15 years when I was growing up. Used to see it cruise slowly by on occasion with the Wide Crager SST's on the back all jacked up. He was single and rode his Harley most of the time with the Camaro on garage duty except for the occasional drive on nice days.
About 1998 Tommy sold it to a buddy of his that jerked the motor and trans out so Dad and I bought it for $1500. We put a 350/350 combo in it and I drove it to college the last couple of years and then he took it back, had it stripped to bare metal and repainted. Unbelievably, the car was totally rust free with original paint and zero body filler.
Long story short, this, along with his '30 Model A streetrod are his toys and he puts a ton of miles on each of them. They get baby'd constantly but driven constantly, rain or shine! Kinda off subject but thought I'd share anyway...
Shane
#theanchorholds
