Old 11-30-2018, 06:38 PM
Default Dirt Missile rebuild begins
So after Thanksgiving - I went up to get the Secret Sauced and Optimized $200,000 “Track Warrior” so I could haul it over to SpeedTech in St. George, Utah
Within a minute of lifting the hood off.... The guys start seeing the mess they have to deal with.
The front brake line had about 2 or 3 more laps before it was cut thru - they’re rubbing on the inside of the wheels because they’re in a bad location.
Almost all the Plumbing is wrong. We’ll discuss this in more detail later.
PCV vent isn’t used with a dry sump - but that’s what Sutton and crew did
Wiring will be redone....it looks like kindergarten class....
The 2000* header coating is burnt completely off a couple cylinders
The power steering pump (KRC) is toast - and the fluid looks like a milkshake. There is NO P/S cooler.
The steering stops apparently are the shocks
The rear axle bearings add camber when loaded
The serpentine belt system is out of alignment - the belt has ground all the black anodizing off the water pump pulley - and is slipping out over the crank pulley.
So — worse than imagined - and I had imagined pretty pee poor workmanship.
Mind you - they’ve only had the car a couple days - so this is just the beginning.
For those of you still thinking Sutton is “the man” — good luck with that.
The Following User Says Thank You to GregWeld For This Useful Post:
jarhead (01-25-2019)
Old 11-30-2018, 08:35 PM
DBasher's Avatar
DBasher DBasher is offline
I don’t understand the rear bearings adding camber...is the id or od of the bearing incorrect or in 15 laps has something failed?
Is this an assessment of how bad or a rebuild regardless? Either way I’m glad this is at a reputable shop with guys that know how things work. I’ll be curious to see what happens with the suspension with everything that’s been learned in the last few months...lower control arms design, 3 link ****ery, craftsmanship.
Hopefully the ****show can turn into something enjoyable on track.
Old 12-01-2018, 12:43 AM
gofastwclass gofastwclass is offline
Wow, sorry to hear that Greg.
Sounds like the SpeedTech guys are experienced enough to get it fixed properly.
I'm in for part two of this saga.
I build my own junk...
The Following User Says Thank You to gofastwclass For This Useful Post:
GregWeld (12-01-2018)
Old 12-01-2018, 12:13 PM
Car uses a FULL FLOATER rear end —- my guess is —- just one more part that neither Sutton nor the “assemblers” knew anything about..... So my guess is —- wrong assembly or wrong spec (suttonized dog crap)..... But I haven’t asked all these details yet — to me — it’s not important what was wrong (everything) — it’s only important that SPEEDTECHS guys know what they’re doing and are even good enough to spot the issues to begin with..... Something Sutton nor the dickheads were.
HE was brilliant and knew everything about every aspect of every part ever made —— just ask him —— well - never mind — he told you whether you wanted to hear it or not. LOL
Old 12-01-2018, 12:41 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Still optimistic about being able to salvage most of whats there GW...?
That's a brave group of guys willing to step into something with so many issues.
Jeff-
Old 12-01-2018, 12:50 PM
Peter McMahon Peter McMahon is offline
Whew, this will be interesting
The Following User Says Thank You to Peter McMahon For This Useful Post:
Old 12-01-2018, 01:58 PM
Greg, you always amaze me with your positive attitude in times of... extreme adversity. I try to maintain the same attitude myself and I really respect that trait in a person.
If SpeedTech's work is remotely as good as their pictures are (sadly I've never knowingly seen one of their builds in person) you are in great hands. ...now if they would just hurry up and post up some destruction / rebuild pictures so those playing at home can learn how to build a proper car.
Old 12-01-2018, 03:59 PM
Che70velle's Avatar
Greg, I’ts hurtful to find out that it’s worse than you thought. Honestly, I thought that the car was already over there. As you already know, it’s in good hands now, and I’m looking forward to seeing progress being made. Hopefully come spring you’ll have a capable, race ready rocket.
Thanks Dad!!
The Following User Says Thank You to Che70velle For This Useful Post:
Old 12-01-2018, 05:22 PM
WSSix WSSix is online now
Good deal, Greg. I'm glad it's in good hands with Blake and his crew. St George should be closer to you now too, correct? Keep us posted.
Old 12-01-2018, 06:25 PM
syborg tt's Avatar
syborg tt syborg tt is online now
Holy crap I can’t believe it’s that bad. That’s just nuts and how the hell did he Scan so many people.
I’ll be the first one to say Hay, I build my cars with a army of people that know what there doing and if I don’t know what I’m doing I don’t try to convince myself or god forbid someone else that I do.
Till this day I still lean on my car friends for help when I get stumped or just go way off in never never land with my crazy ideas.
I hoping you can get this car back to being a race-car as you have a ton of nice parts that just need an intelligent group of guys to get it running and I’m confident the guys at speed tech are the guys.
marty-mj
