Old 12-07-2018, 09:07 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Pulled the mold apart yesterday. Some minor touch up sanding to the gelcoat and its ready for some carbon! Now I need to order it so I can do some infusing next week.
The Following 2 Users Say Thank You to CamaroAJ For This Useful Post:
dhutton (12-08-2018), syborg tt (01-16-2019)
  #252
Old 12-08-2018, 03:11 PM
Goosesdad's Avatar
Looks great AJ! Smoooooth....will reflect in the part!
Maybe you have already thought of this or have tested and it won't be a problem.....When we did glass off road car bumpers, we also broke the mold in the middle for release, like you did. However, we built a truss structure to keep the molds perfectly straight, i.e. didn't rely just on the flange to support the mold from flexing. Since you're going to bag it, I wonder if your mold might flex, even if just a little and your bumper wouldn't be dead straight?
My thought would be to bolt the mold together and if you can make it move even a little, I would clamp it down to something while it was perfectly straight and then laminate a truss structure to the mold. Of course the truss would have to also bolt together in the middle but it would triangulate the mold and it keep it from moving when you pull the vacuum.
Hope that is good advice and isn't redundant.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
  #253
Old 12-10-2018, 06:51 AM
CamaroAJ's Avatar
I've though about that already when I bolted it back together to check fitment. I don't know if I'll build a fixture to hold everything in place or just clamp it to the bench when I get ready to bag it. Yes it does flex otherwise. I have some left over steel from my frame build that I though about using to clamp it to.
Old 12-11-2018, 09:31 PM
It looks good!
The Following User Says Thank You to waynieZ For This Useful Post:
CamaroAJ (12-17-2018)
  #255
Old 01-15-2019, 02:23 PM
CamaroAJ's Avatar
So I made my first carbon fiber infuse part. It is one layer 2x2 then two layers of 12k plain weave. It's pretty strong, but flimsy so I won't be using it. The weave laid down almost perfect so I got that part figured out. I'm going to be laying up another one once I get the mold prepped and the carbon gets here. This time I'm adding a 2mm core and another layer of 12k to it to stiffen it up. As it is right now my iPhone 6 weighs more than this part.
I also chased a vacuum leak for a long time and never got it perfect, which caused some fixable problems in the outer layer. This second part I'm going to envelope the whole mold and that will take care of any leaks I had in the joint. Hopefully more updates on it in the next week or so with a perfect usable part.
dhutton (01-16-2019), jarhead (05-30-2021)
  #256
Old 01-15-2019, 08:12 PM
That’s so awesome!! Good for you for tackling a project like this!
The Following User Says Thank You to GregWeld For This Useful Post:
CamaroAJ (01-16-2019)
  #257
Old 01-28-2019, 02:44 PM
CamaroAJ's Avatar
Bumper 2.0 turned out much stronger. I used a high quality 12k fabric and a 2mm core material along with adding an additional layer of 12k. So it's 1 outer layer of 3k 2x2, 2 layers of 12k 1x1, 2mm honeycomb core, 1 layer of 12k 1x1. it eliminated a lot of the flimsy feel and made it a lot stronger. It has a few blems on the ends, but this is getting painted black anyways so I'm not worried about it. Now that I have my rear bumper done I'm going to move back to the tail lamp housings. In full carbon.
Old 01-29-2019, 07:10 AM
Goosesdad's Avatar
Awesome!!!!
Have a great day!
John
My Build Thread:
Old 01-29-2019, 07:52 AM
SRD Art's Avatar
SRD Art SRD Art is offline
Very cool and inspiring!
-Ben, Your friendly neighborhood Rendering dude, PM me for info!
My SRD Renderings Instagram page
My SRD Renderings Facebook Page
Pumkinator '79 Cutlass Wagon Build
Old 01-29-2019, 08:11 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Aye, that bumper looks like s#!t. Ugly too!! Send that one to me and go back to the drawing board....start over.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
