Old 12-13-2018, 12:08 AM
DBasher's Avatar
DBasher DBasher is offline
That there is one fancy dash! You know, all you had to do was ask and I could have whipped up something similar...of course it’d be cardboard and spray foam but once it was painted you’d never know. Lol
When do the big tires go on?
Old 12-13-2018, 06:09 AM
SSLance's Avatar
SSLance SSLance is offline
We discussed this in Vegas, nevah...
Lance
Old 12-13-2018, 09:58 AM
DBasher's Avatar
Well at least it’ll be fast down the straightaway.
Old 12-13-2018, 10:21 AM
SSLance's Avatar
Fat front heavy MuscleCar on 275s...being fast in sweepers and slaloms.
Small tire cars rule!!
Lance
DBasher (12-13-2018)
Old 12-14-2018, 10:30 AM
hackster's Avatar
hackster hackster is offline
Originally Posted by gofastwclass View Post
Nice bezel! It's good to have friends in low places.
I love this build and all your others, they are just my style.
Thanks and yeah totally helps having some brilliantly talented friends!!
Originally Posted by CMillwheels View Post
Wow, that bezel is awesome. The car’s humming along again in usual Hackster fashion!
Thanks man, gotta get it done so I can help you get that Camaro done before Power Tour.
I think I am going to try it out on the 275's. Wheels will be 3 piece, if I decide I want to flare it I will just be outer hoops, tires and flares away from 315's. I am pretty sure its going to be faster than the truck was so I will have a lot to learn about this thing once its on the track.
Haha!!! That was a good chat too.
**** Talker.....
Been dicking around with it a little bit this week, has enough fluids in it to turn the key over but get no start, no fuel or ignition so we think we have something either with VATS or PASSKEY still enabled. Got a new tune I will load tonight and see if that works to get us fire.
Fuel system got all filled and bled out at the rails so should fire up pretty quick once we get it worked out. Even filled and bled the power steering system.
No Idea how he did it but the Upholstery guy got these done in 4 days. They are not perfect but they are damn good!!! THese are real leather hides with custom stitching on the back piece. Seams are all black thread and a double french stitch added to the outer seams. Very classy looking seats in my opinion.
I am going to do all the insert and foam work on the door panels and have him do the stitching and glue up on them. The plan is to match the pleat pattern on the seats on the 2 door cards the rear sail panel pieces then come up with something for the rear seat area. I am thinking something mid 80's porsche interior is what is in my pea brain. Roll Bar will be painted satin same color as the seats.
Carpet has been shipped. Gotta figure out some seat belts now and get some tubing ordered for the roll bar.
Moving along, test drive could be in a few weeks if all goes well.
Sean
The Following User Says Thank You to hackster For This Useful Post:
syborg tt (12-21-2018)
Old 12-14-2018, 03:40 PM
Those seats came out great.
Originally Posted by hackster View Post
**** Talker.....
Everyone needs a talent - we know what Basher's is.
The Following User Says Thank You to Flash68 For This Useful Post:
DBasher (12-14-2018)
Old 12-14-2018, 06:09 PM
DBasher's Avatar
The seats do look good and the turn around time is impressive! On the rear seat delete vs keeping it, is your guy good enough (or you for that matter) to trim the sides so you can land the bars on the wheel wells? Or are you looking to go into the trunk?
As far as the sh!t talking, you know I’m diggin the car (except the color and little tires ) as well as your skill level and the fact you’re sharing it all.
I’ll see you at turn 2
The Following User Says Thank You to DBasher For This Useful Post:
Flash68 (12-15-2018)
Old 12-16-2018, 04:35 PM
hackster's Avatar
Well, after work on it last week and having a no start issue I concluded that we had no spark, no injectors. Some reading up and poking around in the Tune led me to this gem.
The Start Circuit Checks was enabled. Toggled that to disabled and she fired up, but only ran for a second. Chatted with Ron the tuner and he messed with it a bit over the last part of the week and yesterday and sent me a tune to try today, we had the wrong data in for the LS7 MAF sensor. She fired right up and ran for 40 seconds!!! So ****ing stoked to hear it run for the first time. Had 60PSI oil pressure and all looks good.
First Data Log of it running!!
Start up video
<iframe width="560" height="315" src="https://www.youtube.com/embed/vZKxLwzMUYM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
So I got the rear diff all filled up with fluid and friction modifier and buttoned up. Got the catch can drain plumbed in and insulated since it will have to be somewhat close to the exhaust and pulled the horrible outer window scrapers off and got some new Barton parts installed. I had to pinch the tracks a fair bit to get them to stay in but all in all a nice product. I have inners but gotta figure out door panel materials before that.
Onto the next steps now that we know it runs. Roll bar, harnesses, dash guages, carpet, bleed brakes and clutch, coolant in both systems the list goes on and on =)
Good fun though.
Sean
