  #25
Old 01-05-2019, 04:45 PM
jasonz28camaro jasonz28camaro is offline
I chose to use the ITCBillet Gen V swap mounts they sell with short and wide engine mounts. One of the main reasons I went with these is because they advertise you can use these with the stock vacuum pump and thats something I wanted to achieve. I pulled the vacuum pump and went ahead and sat the motor down into the subframe to check fitment.
As you can see I'm a little ways off from getting them lined up so I reached out to ITCBillet for advice.
