Old 01-19-2019, 08:49 PM
cjsgarage cjsgarage is offline
If you run hardline except for the flex for tank drop-down and from firewall to block, you'll save on serviceable pieces.
I like wiring. No joke.
The Following User Says Thank You to cjsgarage For This Useful Post:
camcojb (01-19-2019)
Old 01-19-2019, 09:09 PM
Doug1's Avatar
Doug1 Doug1 is offline
from my iPhone using Tapatalk
Pretty much what I do.
1 from rear bulkhead return fitting in tank
1 from in pump in tank to fuel filter
1 from fuel filter to rear bulkhead pressure line
1 from front pressure bulkead fitting to filter
1 from filter to Y adapter to split to fuel rails
2 from Y adapter to fuel rails
2 return lines from fuel rails to regulator
1 from regulator return to return bulkhead
Untitled by by [url=https://www.flickr.com/photos/159188510@N03/],
Untitled by [url=https://www.flickr.com/photos/159188510@N03/]
