Old 01-16-2019, 10:08 AM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Hoping to see more build progress pics soon.
Ric
Old 01-16-2019, 04:47 PM
gofastwclass gofastwclass is offline
The Secret Sauced V/C’s were a problem from the get go!! They were leaking from day one.....and I remember thinking — “I’ve NEVER EVER seen a LS motor with leaking V/C’s.... “
If I get them back I plan to take them way out in the desert and add some modifications to them with a 6.5 Creedmoor...... Then I’ll sign them and send one to you!
Now THAT's funny!
I'll make sure to never make you angry.
I build my own junk...
The Following User Says Thank You to gofastwclass For This Useful Post:
GregWeld (01-18-2019)
  #173
Old 01-18-2019, 03:44 PM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
What ever Tim says goes on the dry sump, LOL, Kurt and him did more experimenting then probably anybody in the country. I am running factory 2 stage LS7 pump with A.R.E. pan, doesn't make enough vacuum to properly scavenge, so ended up using multiple vent tanks to cure my oil puke issues. Works great but took a while to dial in.
Ron Schwarz
Old 01-19-2019, 07:16 AM
Tony V Tony V is offline
Originally Posted by 71RS/SS396 View Post
How you plumb the topend of the engine is really dependent on the scavenge ability of the pump and whether it can maintain vacuum on the crankcase when the engine is wound up. If you can't maintain vacuum when the engine is at max rpm you have to vent the crankcase pressure to somewhere or you're going to have blow-by issues.
I started out with a 3 stage Dailey that made vacuum at idle but with the 4.125 stroke crank I have it couldn't maintain vacuum when we revved it up. I added 2 more scavenge stages, I can now maintain 15" of vacuum at 8,000 rpm and picked up 20 hp. I initially ran it sealed but with street driving I started seeing moisture accumulation in the tank oil cap and the valve covers. I plumbed a -4 line from the drivers side valve cover to the top of the tank to turn the air over and cured the moisture issue.
What I have done with the 3 stage pumps is to run one -12 line from the valve cover to the top of the tank, you can run it to the tank breather but you'll just fill with oil quicker.
Tim, really appreciate you sharing....Greg can't wait to see some progress pics and now that you're down here in sunny AZ maybe i'll get a chance to the missile on track days. love this thread, learning what not to do and how to correct it, unfortunately it came at a cost for Greg, hang in there!
now to my question; I have a 3 stage Dailey and plumbed a -10 from valve covers into my breather line on my 3 ga tank and would usually see accumulation of oil in my breather can that would fill it 3/4 full after a full track day, is that normal?
The Following User Says Thank You to Tony V For This Useful Post:
GregWeld (01-19-2019)
  #175
Old 01-21-2019, 07:27 AM
71RS/SS396's Avatar
I would just run a -12 off of one valve cover directly to the top of the tank so you don't keep filling the breather tank. Are you sure you aren't over filling your tank?
Old 01-21-2019, 07:30 AM
71RS/SS396's Avatar
I wouldn't claim to be the authority on dry sumps. I know what works on the combinations we tested.
Old 01-24-2019, 07:08 AM
Default Dirt Missile rebuild begins
I forget who was asking —- but this is the mod we came up with for the lower control arm (LCA)..... Once we have the specs locked in for alignment — our thinking is we’ll weld this fully and eliminate the bolts that will allow for adjustment.
Sent from my iPad using Tapatalk Pro
The Following 2 Users Say Thank You to GregWeld For This Useful Post:
FaBrycation (01-24-2019), gofastwclass (01-25-2019)
  #178
Old 01-24-2019, 07:10 AM
SSLance's Avatar
SSLance SSLance is offline
So simple...yet so effective...
Lance
GregWeld (01-24-2019)
  #179
Old 01-24-2019, 07:12 AM
SpeedTech built partial wheel tubs up front to keep “track debris” from just blowing all over the stuff on the firewall etc..... for those that have never run Hoosiers — you have no idea how sticky they are — and subsequently - how much junk they pick up and hurl!!
The Following User Says Thank You to GregWeld For This Useful Post:
  #180
Old 01-24-2019, 07:20 AM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
If you keep taking the dirt track out of this thing, your going to have to rename it... again.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
The Following User Says Thank You to CJD Automotive For This Useful Post:
