01-30-2019, 06:55 AM
Originally Posted by 7firebird1
That is definitely a sweet ride TY!! I’m digging that rear end setup! I can’t tell if that is a 9” rear end or 12 bolt. I have a complete Hotchkis setup now....considering ditching the leaf springs and doing a four link or something like what you have.
that actually looks like a 10 Bolt. The 9" Rear Housing would look like this
01-30-2019, 07:03 AM
What kind of warranty do your products carry T.C.?
BMR product applications are warranted to be free from defects in material and workmanship under normal use and service for a period of (2) two years from the date of sale to the original purchaser. Obligation under this warranty is limited to product replacement but not the reinstallation of the replacement product or other incidental costs. This warranty does not cover any product that has been subject to misuse, neglect, alteration, accident, or improper installation. Normal wear shall not be considered a defect under this warranty. All warranty adjustments are limited to replacement or credit of returned merchandise. This warranty specifically excludes impact damage or damage to powdercoat.
Beyond the 2 years, I try to be reasonable, but truth be told and I think this would apply across the industry, if you have a problem, it usually happens sooner than later. And luckily we don't have many problems.
01-30-2019, 07:23 AM
POC 10-bolt
10-bolt... 10 years no problems!
Complete bolt-in installation!
Ty Ingle, USAF Retired
FREEDOMBIRD Hoodpins.com, Inland Empire Driveline, Billet Accessories Direct, Modo Innovations, AutoRad Radiators, Morris Classic Concepts, Marquez Design, Anvil Auto, Fesler Billet, US Collision (DOOM), AGR, Pro-touringF-body.com, Phoenix Transmission Products, Shiftworks, ACC Carpet, Hedman Hedders, BMR Fabrication, American Autowire, MityMounts, TIN INDIAN Performance, Kauffman Racing Equipment, Pypes, RobbMc Performance, WMC, Holley, NOS, PST
The Following User Says Thank You to OLDFLM For This Useful Post:
01-30-2019, 07:35 AM
I think I might have to pull the trigger on the torque arm setup! I have a 12 bolt now that I need to add a posi unit to as well. What shocks would you recommend? Ride tech or QA1? I also have Detroit Speed frame connectors and a complete six speed Tremec manual swap from American Powertrain....will this torque arm setup work in conjunction with all of those products without any major modifications?
01-30-2019, 07:37 AM
Ty, it seems like I am building my 71 very similar to what you have built. I was wondering if maybe I could get in touch with you and pick your brain a bit.
01-30-2019, 07:59 AM
12-bolt & Coilovers
12-bolt will work fine just tell BMR when you order the Torque Arm and it'll bolt right up! Another benefit of removing the leaf springs and going with BMR's torque arm is that I'm running a 295/40/18 out back with no minitubs!
Coilovers... my recommendation would be to really think about what you'll ACTUALLY be using the car for and then decide. I went with AFCOs and while they are not "the be$t of the be$t" but they've worked fine for me for 10 years.
I'd ask BMR what they recommend, and look at the vendors that support this site... you have plenty of options there.
PM me for my contact info... always happy to help a fellow Buckeye!
01-30-2019, 08:27 AM
Thanks brother! Will do.
01-30-2019, 10:00 AM
I recommend ViKing C207 Coilovers in the Back
02-07-2019, 06:56 AM
Will this setup interfere with my DSE subframe connectors?
Thread Tools |
Display Modes |
Linear Mode
