Old 04-20-2019, 09:43 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
I don't have any photos for you, but the RS setup I installed in mine was pretty simple and straight forward. Took all of about 20 min.
At the beginning I was having some difficulties to center and align the LED board within light housing due to smaller size boards compared to the previous design, but yesterday I got it all figured out.
However, when I wired up the parking lights, the little green indicators for the turn signals/hazard on the classic instruments cluster come on and stay on when the parking light is turned on. When I turn the hazards or the turn signals on, the dash indicators blink at a higher intensity like the parking lights. It is strange.
I did replace both the flashers with LED flashers and not sure why this is happening.
This phenomena happened just when I had installed Digi-Tails parking lights.
72 Camaro RS:SOLD
68 Camaro:
Old 04-20-2019, 02:01 PM
randy randy is offline
Local to Dallas at all. I would be glad to help
Old 04-23-2019, 11:32 PM
72Z/28's Avatar
Thanks for the offer Randy but I live on the other side of the world. Just an update on what I am planning to do and what I have done so far:
I received my new parking light gaskets ( rubber type). Even though Digi-Tails claimed that the LED board design had been improved to a smaller board to prevent the gasket from covering/blocking some of the LEDs around the board boundary. Unfortunately, this is not true because I had to trim the part of the gasket that blocked the LEDs.
Digi-Tails customer service sucks as well. They responded only once to my queries , and have not heard from them regarding other queries.
Regarding the indicators on the gauge cluster, I am awaiting the LED flashers with ground wires and see the results afterwards.
I wish I had bought a good quality LED bulbs instead of going though the hassles with Digi-Tails
72 Camaro RS:SOLD
68 Camaro:
Old 04-09-2020, 02:36 PM
paulk68 paulk68 is offline
wow this came up just as i started working on mine and am having the exact same mounting issues? how did you center attach and have the gasket not block any of the led's?
Old 04-09-2020, 03:21 PM
130fe 130fe is offline
Post
Do you have any pics? I have digitalis in the front and rear of my car.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 04-09-2020, 03:51 PM
So before they used to extend all the way out to the screw holes. Now they just kinda float. The rear sucks too because it is so far off center it makes it hard to move them around. And finally when I put the gasket on it blocks a whole row of leds.
Old 04-10-2020, 05:48 AM
Post
Can you wrap the gasket around it? Would that hold it?
Chris
1968 Camaro SS
LS3/T56
