Old 06-10-2019, 10:08 AM
ANVIL1's Avatar
ANVIL1 ANVIL1 is offline
Default Anvil Inner Fender
You can run 315s with our (Anvil) inner fenders with the right back spacing.
MaTT
ANVil Auto
__________
'69 Camaro
'73 Camaro
'10 Camaro RS/SS
'96 Viper GTS
'70 Bronco
'69 Mustang sports roof
The Following User Says Thank You to ANVIL1 For This Useful Post:
redfire69 (06-10-2019)
Old 06-10-2019, 06:58 PM
VTtransam VTtransam is offline
Thank you Matt. I don't have the Anvil inner fender extensions, and still have the stock outer fenders. What backspace do you typically see with your inners and 315 tire?
I'm appreciative that both vendors took the time to reply. Thank you!
Old 06-14-2019, 09:40 PM
alongfortheride alongfortheride is offline
No offense I had speedtechs inner fenders with the extreme subframe. Do not do it the inner fenders fit poorly at best. Ended up reworking stock steel inner fender wells for a nice clean look.
Old 06-19-2019, 11:19 AM
Blake Foster's Avatar
WOW we install then all the time and they look AWESOME!! they are not a "BOLT IN" they are made to fit with some modifications. here are 2 examples.
Blake Foster
www.speedtechperformance.com
The Following 3 Users Say Thank You to Blake Foster For This Useful Post:
camcojb (06-20-2019), dhutton (06-19-2019), jarhead (06-20-2019)
Old 06-19-2019, 12:13 PM
Here is a pic of the inners that I just got today from a customer
Blake Foster
The Following 2 Users Say Thank You to Blake Foster For This Useful Post:
Old 06-26-2019, 09:33 AM
Show where the inner and the fender lip meet. Sorry they do not fit very well. I understand out of sight out of mind. However for my experience was they did not fit very well.
Old 06-26-2019, 09:36 AM
Made to fit with some modification. Just like all your parts. True story there.
Old 07-17-2019, 08:02 AM
I went with 295s on 10.5" wide 18" diameter rims, 8.25" back spacing. Guessing at the suspension set-up, I went auto crossing for the first time this past weekend. No rubbing or anything with the 295s. 315's would be tight but I think I'll try them next!
Old 07-26-2019, 11:25 AM
You sound upset???
Your saying the fender lip area was more work to make fit than reworking the stock inner? I doubt that. But not here to argue.
The inner was designed to come out to the inside of the fender and drop straight down so you get the maximum space possible for compression travel under braking. The inner lip needs to be worked to provide more clearance with a 315 tire for sure but hey you don't have to widen the fender!!
sorry you were not happy with the product we have not had any other negative comments.
Blake Foster
Old 07-11-2021, 10:06 AM
holschen's Avatar
holschen holschen is offline
im sorry blake i would never recomend anyone buying anything from you before getting a waranty i fit properly before. if i buy something for alot of money , i expect it to fit . i have pics to show. but it would be better if you put up pics and explained what minor works means.
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
