Old 06-12-2019, 08:40 PM
randy randy is offline
I went from my old non adjustable 450lbs to 550 Jr I single and my car handles amazing with that setup. I’m still running the 250lb rear spring. My buddy has a set of non adjustable a laying around that he might sell you for the same subframe and Quadra link. If you want a great ride and handle well just go with the single adjustable 550 and 250 springs. If you want to race it more go with a slightly stiff spring and adjustable with remote canister. Call jri and dse. They are helpful.
Also where are you located?
Old 06-12-2019, 09:57 PM
jcal87's Avatar
jcal87 jcal87 is offline
Well it already has the 450 and 250 in the rear. I called DSE today and they recommended the single adjustable JRI’s that they are putting on there frames now. I am in located in McKinney
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 06-13-2019, 10:40 AM
Musclerodz's Avatar
the 450's they were sending with subframes was too soft out of the box. hence the reason you have a blown shock. 550 is plenty and will give a good ride, 250 in the rear is fine as well.
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-14-2019, 05:20 AM
dhutton dhutton is offline
Curious what shop is recommending those high spring rates. They are pretty hard core.
Old 06-14-2019, 08:56 AM
jcal87's Avatar
I thought I sent you a DM. Did it not go through?
1968 Camaro Blue
Texas A&M Alumni
Old 06-14-2019, 09:14 AM
No messages.
Old 07-16-2019, 07:02 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
I was originally running 550 front and 250 rear springs on Dust Off with my DSE sub and G-Link 4 link rear with AFCO double adjustable shocks all around. I had a problem with the car porpoising at speeds above 110 which the shocks could not control even with maxed out rebound settings. I thought the shocks were the problem but before I did anything I contacted Rod Prouty and after discussing the situation he recommended upping the spring rate to 800 front 300 rear. After installing the new springs I was able to tune out the porpoising without having to max out the current shock settings. I was concerned that street ride quality would suffer but I was pleasantly surprised to find that by using a softer shock setting on the street the ride was surprisingly smooth. Based on my experience I would not hesitate recommending higher rate springs with double adjustable shocks so you can tune for both street and high speed track.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
