06-21-2019, 07:28 AM
to the top!
07-21-2019, 07:33 PM
to the top!
07-22-2019, 02:21 PM
I'm just throwing this out there since I'm going to be using one of these trans for my car and have been keeping an eye out for them. There are a few on ebay for $1,750 shipped. More than likely a no, but if you want to do that I'd buy it.
Instagram- camaroaj
08-04-2019, 07:35 PM
Are those the Z06 version? When I look them up they are the Stingray gearing.
I lowered pricing on the transmission and total parts shipped.
08-10-2019, 07:53 AM
Clutch parts, slave and transmission harness sold
The Following User Says Thank You to gnx7 For This Useful Post:
09-22-2019, 07:48 PM
Somebody buy this and build something bad ass with it!
I have an n/a 800hp 441ci LS engine that could pair up well with this
05-03-2020, 09:49 PM
transmission/diff/coolers/lines/eLSD controller/both axles/outer hubs tentatively sold
05-20-2020, 07:27 AM
Here is what I have:
TR6070 with cooler/lines $SOLD$
TR6070 diff with cooler/lines $SOLD$
both axles $SOLD$
shifter linkage $SOLD$
diff isolator bushings/mounts $SOLD$
eLSD actuator/pump $SOLD$
2016 Z06 Corvette 7 speed manual: (10K miles approx) rear cradle, upper/lower A-arms, uprights (where the axles slide into on the outer portion at the wheels), leaf spring, sway bar and end links (no brakes... but I have them for additional cost). $750
2015 Z06 Corvette: (6K miles approx) front cradle, upper/lower A-arms, front hubs/uprights/bearings/factory wheel studs (No sway bar or leaf spring): $750
2015 z06 steering rack for the 14.5" steel brake option $SOLD
2015 Z06 front 14.5" steel rotors, red calipers/6K mile brake pads
2015 Z06 rear 14.2" steel rotors, red calipers/6K mile brake pads $SOLD(do not want to separate these from each other. It is being sold as a complete front/rear setup. Pics up next week)
C7 Z06 carbon torque tube 10K miles $650
C7 Z06 carbon driveshaft 10K miles $500
Clutch slave $SOLD$
transmission harness $SOLD$
leaf spring Front $SOLD$ (rear still available)
twin disc clutch/pressure plate $150 $SOLD$
Brakes and steering rack related items sold
10-06-2019, 11:01 AM
Just picked up a used C6 aluminum torque tube/bellhousing and dshaft so that can be easily shortened to swap this into something... or lengthened if that is the goal.
$150
10-27-2019, 11:22 AM
Front leaf spring sold
| Thread Tools |
| Display Modes |
Hybrid Mode
