Old 07-14-2019, 12:27 PM
zz430droptop67rs's Avatar
zz430droptop67rs zz430droptop67rs is offline
Do you have good vacuum to the modulator?
Old 07-14-2019, 09:48 PM
g356gear's Avatar
g356gear g356gear is offline
I was having another issue with no brake boost at the same time. That issue was a cracked inlet of the line from the booster to the manifold. That is fixed, and the brake boost is back. Could that issue also affect transmission shifting?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
