Old 08-02-2019, 07:19 AM
130fe 130fe is offline
Post
looking for something like this?
http://www.bodenzord.com/archives/59...k90HbBJ92EcXSc
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 08-02-2019, 07:37 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Originally Posted by 130fe View Post
Thank you, I think that will work pretty well. The link had a link to Part 2 of his write up and they have a block that is wired relays and a buss bar for fuses. Looks like I can power the fuse buss bar off one relay and use the 4 other relays to control some other functions.
Instagram- camaroaj
Old 08-05-2019, 02:59 PM
dhutton dhutton is offline
Lot of options here:
https://www.ebay.com/sch/i.html?_fro...temCondition=3
130fe (08-05-2019)
Old 08-05-2019, 07:17 PM
WILWAXU WILWAXU is offline
Painless has a couple different setups. I used one of the 7-circuit kits on a project. Nice setup, and well labeled.
https://www.painlessperformance.com/wc/fuse
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 08-06-2019, 06:33 PM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is online now
Take a look at the Eaton Bussmann series:
https://www.waytekwire.com/products/...ution-Modules/
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
Old 08-08-2019, 07:01 AM
CamaroAJ's Avatar
I think this is what I've decided on. Uses mini fuses and micro relays and can support a constant 250A. I'm thinking 2 should work, one under the hood to put fuse protection on the injectors, coils, o2 sensors, MAF, and supercharger bypass solenoid, chiller pump, and still have room left for expansion. I'll piggy back off the Infinity Box ECM power feed to act as a wake up circuit for the relays and have an ignition 1 and 2 relays to send power to the fuses.
Interior wise I can feed everything from it so I don't have to buy another $500 Infinity Box power cell and piggy back off one of the ignition power feeds as a wake up signal to the relays and have live battery fed circuits for radio keep alive and interior lamps.
Not a bad size either, 6"x2.25"x2.7". Wires feed out the back so it will need some kind of stand off base or mounting panel.
https://www.waytekwire.com/item/4599...waAihoEALw_wcB
Instagram- camaroaj
