Old 01-06-2020, 12:44 PM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Probably? well you would need to see what clearance the tires/wheels have now being they would move in about 1 1/8+" per side next issue is the perch width
Center to center of the perches should be about 42 1/2" on 67-69's and early Nova's Looks like 43.5" so without moving the perch's its not going to "Fit" without some modification and also wheel offset can help
Note: if its an original Chevy II 12 bolt its worth more than a correct 67-69 12 bolt would be unless its the elusive BE coded Copo rear
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 02-22-2020, 03:45 PM
elwaupo elwaupo is offline
I think I’ll just sell that Nova rear end as it really should go on the correct car.
