Old 02-20-2020, 06:11 PM
Malitude was even further out of your comfort zone I'd say and that was a grand slam of a car in my opinion.
As much as I'd love to see your idea of a 2nd gen, I'm still amazed and appreciative of how open you are with all of your builds. Thank you, Mark.
Old 02-20-2020, 06:42 PM
jmac jmac is offline
Ok, another question for you Mark!
With the DSE subframe, what transmission cross member are you using?
I know the DSE engine mounts move the engine back 1.5 inches, and they say to use a stock style cross member. What are you using in this build, and what have you used in past builds? The closest pic I could see was on post #61, but it's far in the background and I can't really make it out.
Thanks again for your time and expertise!
The Following User Says Thank You to jmac For This Useful Post:
Tshannon4570 (06-13-2021)
Old 02-20-2020, 08:17 PM
I’ll let him verify but looks like (holley) hooker blackheart one to me.
https://www.holley.com/products/ls_p...parts/12626HKR
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 02-21-2020, 04:58 AM
Sled Alley Sled Alley is offline
The LT motor mounts and trans cross member are both hooker blackheart. We built the first set off gunner and got all of the angles set and holley is now producing them. They fit great and everything bolts in as it should. You do have to raise the tunnel to get correct driveline angle
http://www.sledalley.com
The Following 2 Users Say Thank You to Sled Alley For This Useful Post:
dhutton (02-21-2020), jmac (02-21-2020)
Old 02-21-2020, 06:25 AM
Ahhhhhh, that's right, I forgot this was an LT series engine!
What have you guys done for LS engines in the past using the DSE subframe? I know DSE has their own engine mounts for the LS engine for their subframe, but kind of leave you hanging on the trans cross member.
And would you happen to have any pics of the interior trans tunnel mods you've performed?
Thanks!
Old 02-21-2020, 06:56 AM
JON Q's Avatar
JON Q JON Q is offline
Thanks!
If you go back to the build of Jackass 2.0, you will find the pictures there on the cross member Mark has built on Hellfire and JA for the LS9. It is on page 68. If you look at some of the DSE builds you will also find they have built a similar setup
The Following User Says Thank You to JON Q For This Useful Post:
jmac (02-21-2020)
