Old 04-02-2020, 04:33 PM
Wow that looks nice!
Old 04-02-2020, 04:51 PM
Goosesdad's Avatar
Originally Posted by DWC View Post
So smooth, very impressive.
Daniel
Originally Posted by two-piece View Post
Very impressive.
Originally Posted by 214Chevelle View Post
Whoop, there it is!!
Every time I open this thread I am amazed.
Originally Posted by Sonar Chief View Post
Great job with the firewall the hard labor pays off with beauty!!
Looking good!
I think I'll take the ice pick to the eye instead...
Originally Posted by CamaroAJ View Post
So I can send my car to get finished in about 2 weeks?
You guys are so encouraging, the positive energy and the depth of knowledge...wow! I'm so glad to be a part of this community.
Thank you. Hope everyone is safe!
Have a great day!
John
My Build Thread:
Old 04-02-2020, 05:15 PM
To get to watch builds like this so are we!
The Following User Says Thank You to waynieZ For This Useful Post:
AB69Z (04-02-2020)
Old 04-12-2020, 10:42 PM
Goosesdad's Avatar
Fab'd up a mounting plate. The cabin fire bottle and some electronics will get mounted here.
Some rust encapsulator and internal frame coating sprayed in the rear frame rails, inside the tubs and the rockers.
Some sealer in a few places.
Masked, scuffed, cleaned.
Sprayed with Raptor. 22 tip, reduced by 10%, 12-18lbs. Used about a gallon.
Have a great day!
John
My Build Thread:
The Following 10 Users Say Thank You to Goosesdad For This Useful Post:
camcojb (04-15-2020), fleetus macmullitz (04-13-2020), jarhead (12-15-2020), OLDFLM (04-13-2020), Roscoe03 (04-12-2020), slenning (06-15-2020), Sonar Chief (04-13-2020), streetbird (04-14-2020), syborg tt (04-22-2020), WILWAXU (04-13-2020)
Old 04-12-2020, 10:49 PM
Wow what a nice finish! I like that so much more than the ruff finish. Beautiful job.
Old 04-12-2020, 11:36 PM
Roscoe03 Roscoe03 is offline
That looks amazing! Nice work.
Old 04-13-2020, 06:46 PM
two-piece's Avatar
two-piece two-piece is offline
Looks killer
Old 04-14-2020, 12:50 PM
streetbird's Avatar
streetbird streetbird is offline
wow I love the finish of the liner that way. What gun you taked for that?
What is the equivalent in mm for the .22 tip? and last question, what you taked to disolve the liner.
The French Frog
Old 04-14-2020, 09:19 PM
Goosesdad's Avatar
Looks killer
Fantastic! Great job, John!
Thanks guys!!
No real fancy gun..Devilbiss Finishline. Think it's a $200 gun.
Tip sizes are in mm. So that is a 2.2mm tip.
I used PPG DT885 reducer. It's pretty expensive for this... I think you could use any good urethane reducer.
Pressure and material volume adjustments make the texture and thickness. This was my first time spraying it and I'm a total rookie with the gun. Honestly, it was very forgiving and responded well to adjustments including pattern. I dialed it tight for small areas and then to around a 4" spread for flat areas. Don't mess around after you are done spraying...get to cleaning the gun!!!
Have a great day!
John
My Build Thread:
Old 04-15-2020, 12:28 AM
camcojb camcojb is online now
Originally Posted by Goosesdad View Post
Thanks guys!!
I love that liner, had it on my Chevelle. Very clean and uniform look, and is awesome at hiding dust and debris on a car that's driven.
The Following 2 Users Say Thank You to camcojb For This Useful Post:
Goosesdad (04-19-2020), syborg tt (12-28-2020)
