Old 04-05-2020, 01:31 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by 67_camaroRS View Post
Hey mark, what Master Cylinder, Brake Booster and proportioning system are you using on this car? Thanks
The Detroit Speed booster and master. Prop valve Willwood off memory.
Stielow Engineering
Old 04-05-2020, 04:28 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
If you’re running ABS why are you using a prop valve? I’ve seen it on a few of your builds and with the C5 ABS I have for my car I know it controls bias. Is it just a back up fail safe you’re using it for?
Instagram- camaroaj
Old 04-05-2020, 04:32 PM
Stielow's Avatar
Yes I balance the system with ABS turned off then turn on the ABS. Yes it is an event of ABS system fault. Not likely but give me a piece of mind.
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
pannetron (01-03-2021), rat_rod_russell (10-16-2020), vdrivinmike (04-05-2020)
Old 04-05-2020, 06:04 PM
CamaroAJ's Avatar
Good information. Does having the prop valve in it set to balance the car with the ABS off mess with the balance when the ABS is turned back on?
Instagram- camaroaj
Old 04-05-2020, 08:19 PM
Anyone want to bet Mark's brain is running overtime with this quarantine thing ... off work, isolation,... coming up with his next great part, mod, build ,trend
Old 04-06-2020, 06:10 PM
Stielow's Avatar
Not hardly. Binge watching TV show with my wife and the dogs.... oh and I cleaned the shop.
Stielow Engineering
Old 04-06-2020, 06:34 PM
jmac jmac is offline
Have anything cool to sell?
My 1967 Camaro
