Old 04-24-2020, 01:05 PM
syborg tt's Avatar
Originally Posted by CamaroAJ View Post
Is this a street car only? I ask because I know its really easy to boil power steering fluid during track days or autocross. A cooler would be a good idea in any case. I like the machine bushing idea for washers, I'm going to have to remember that.
Strictly a street car as I don't feel it has enough safety features in it that would save my life if I crashed. So this
one will do the Power Tour and see a bunch of mountain bike trails.
I also have the Cayman R and the 2010 Camaro if I want to hit the track or autocross. Something about having
airbags, ABS and updated safety features that at this point in my life seem really important.
marty-mj
Sonar Chief (04-24-2020)
  #1352
Old 04-24-2020, 05:15 PM
syborg tt's Avatar
Coil Brackets (02-02-20)
So at this point I am assuming at this point that my coil brackets are upside down so I am going to flip them to see if the coils come down just a little bit to take the tension off the plug wires. If not I am going to have to remake the wire as I don't like how tight they are.
and yes that is a mountain bike tool being used on my car. Which got me thinking....
At some point the Custom Works Carbon Valve covers we be heading over to Gonzo Details for paint correction and a paint sealer.
Flipped
Well that didn't work out so it looks like we will be making new wires.
marty-mj
Old 04-24-2020, 05:27 PM
syborg tt's Avatar
Next up is planning, neatly hiding and running wires so they will be easy to access if I need to service them.
making a new hole.
Grommet installed and I promise I will clean up the DEI Boom Matt to make it look nice.
Back to the Holley Terminator wiring and I am hoping all of my planning pays off with all of the hose routing and
wiring. Confirming the location of where I want to mount the relays. Once I feel confident I will install the "Weld Mounts"
which are a stud that are glues in with panel bond.
These are going to be fun to put the washer, lock washer and nut on.
I think this is the final.
More notes on the blue tap.
marty-mj
Old 04-24-2020, 05:39 PM
syborg tt's Avatar
Lokar Dip Stick (02-02-20 )
Not liking the stainless look so in order to tone it down just a little I wrapped it in the High Temp Tech Flex wrap.
Being hones if I didn't already have this I would be putting in a stock dipstick.
Instead of cutting with Scissors they recommend a Hot Knife so a quick trip to Harbor Freight and $20.00 later this will work.
I used an adhesive based heat shrink so it's nice and tight and I am hoping the engine heat doesn't cause an issue. I am also
consider a factory dip stick as they work and it's already black so it will disappear when you look in the engine bay.
Well it at least looks better.
More stuff arrived.
marty-mj
Old 04-24-2020, 06:03 PM
syborg tt's Avatar
Back out in the Garage again (02-16-20)
I was hungry so I looked in my wife's car and found some snacks
Another harness that I am going to redo...
This was the original fuel pump wire.
Time to remove and clean up the harness.
While I am here I might as well clean up the tail light harness.
Odd it doesn't look so bad on the ground...To late now
My desk for the next couple hours.
Looking better already.
marty-mj
Old 04-24-2020, 06:13 PM
syborg tt's Avatar
Here we go.
Bye Bye
time to get rid of a few feet of wire.
shorter is better.
this is how much wire was removed. (02-17-20 )
marty-mj
Old 04-24-2020, 06:21 PM
syborg tt's Avatar
Looks like my desk is back.
time to splice and join.
and Thank you Foster Grant for making Multi-Focal cheaters as I needed them for this project.
Time to wrap with Tech Flex Wire Wrap
More notes
marty-mj
Old 04-24-2020, 07:01 PM
syborg tt's Avatar
Moving back to the front of the car. (02-19-20)
The Dot's represent where I will bond in the "Weld Mounts"
Looks like there is plenty of clearance the bend doesn't look that bad
Vintage Air
Studs going in.
Off to Ace Hardware for more clamps and a Chunky Bar.
While the epoxy is drying I am going to jump back to the taillight harness.
and yes I put this Circle in for a reason.
marty-mj
Old 04-24-2020, 07:08 PM
syborg tt's Avatar
Back to the Holley EFI Harness (02-20-20)
Remember the blue notes.
Since this is a ground stud I removed all of the paint and I also removed the paint from the inside of the cowl.
Good News every stud was place in the correct location + or - milometers.
The view from the back seat
marty-mj
Old 04-24-2020, 07:11 PM
F'in mine's Avatar
Marty, that stay at home advisory is really working in your favor by getting a bunch of small detailing stuff done. I picked up some of that wire wrap to use as a conduit for wiring going from the trunk area to glovebox, keeps them nice and neat & protected.
Hey if you don't mind...... in the pics of your spark plug wires, your grommet on your firewall that feeds your main harness looks nice and snug, care to share which one you used. Thanks.
Keep up the tidy detailing!
1969 Camaro SSRS
Simon
The Following User Says Thank You to F'in mine For This Useful Post:
syborg tt (04-26-2020)
