Old 06-06-2020, 04:25 PM
F'in mine's Avatar
Working on cleaning up the wiring on the LT5 crate harness. The LT5 uses 2 ECMs.
I guess the 2nd ECM triggers the other new port injection system. How are they activated, engine rpm?
1969 Camaro SSRS
Simon
Old 06-06-2020, 06:44 PM
That's what I'm wondering, too, Simon. I didn't realize these engines had two ECU's
Old 06-07-2020, 04:21 AM
Stielow's Avatar
Stielow Stielow is offline
The 2nd ECM S53 is basically a slave ECM that drives the 8 extra Port Fuel Injectors. It is controlled by CAN messaging from the primary E99 ECM. The engine calibration lives in the E99 ECM.
This is needed because a LT5 has 8 Direct Injectors and 8 PFI injectors.
HP Tuners has cracked into the ECM so now you can tune it.
Stielow Engineering
The Following 7 Users Say Thank You to Stielow For This Useful Post:
130fe (06-07-2020), dmc69 (06-07-2020), F'in mine (06-08-2020), fleet (06-07-2020), kwhizz (06-07-2020), Will382 (06-07-2020), WILWAXU (06-07-2020)
