Old 07-08-2020, 04:04 AM
130fe 130fe is offline
Thumbs up
Andrew, do you think the C7 fan would work well with the LS3 GMPP fan wire (without PWM)? I was the one that asked you questions about the C7 fan dimensions on IG yesterday. I currently have the Entropy radiator (and it’s controller) am looking at other radiator/fan options.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 07-08-2020, 05:15 AM
andrewb70's Avatar
Chris,
The fan wire on the GMPP harness is just a ground trigger for a relay, and will definitely not work with the C7 fan. Spal does offer tidy little controllers for their brushless fans, which I'm certain will work with the C7 fan. However, they are not adjustable, and you have to make sure to pick the right one for your thermostat, otherwise the fan will run all the time. It's definitely not as elegant as what I did on Sean's truck.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
