Old 07-30-2020, 05:54 PM
Originally Posted by Beechy View Post
Prolly can be done with regular Bosch 5-pin relays
You lose out on the load sensing aspect, but 2 relays would certainly work from a pure function standpoint.
Old 08-20-2020, 07:40 PM
Caliper is mounted. It works perfectly with the one-touch window controller.
The Following User Says Thank You to MtotheIKEo For This Useful Post:
70UglyBird (08-21-2020)
Old 05-16-2021, 05:05 AM
69Toronto 69Toronto is offline
Im just about to finish my tesla install, I used a module to control the caliper similar to pantera's
I have installed only 1 tesla caliper....do you think this enough to hold the car from rolling?
Old 05-18-2021, 09:41 PM
1 is enough to hold my car firmly on a steep driveway. It very noticeable if I leave it engaged and try to drive away.
Did you use the Pantera controller or something else?
Old 05-20-2021, 02:57 AM
thanks good to know...cant wait to see mine work
(car still paint)
I did not use the pantera controller, I found an actuator controller or 99.00 and some generic red/green button
once i get my car back I can take a look and post the name of the manufacturer
Old 09-03-2021, 09:53 AM
Perry Mitchell Perry Mitchell is offline
I was hoping to get more info on the Tesla parking brake conversion for my 67 Camaro. What is the caliper made of? I'm hoping aluminum so I can remove the Tesla logo and get them anodized to match my Wilwood calipers. I also need more info about the recall that applies to the calipers. Can I fix them myself? I am trying to find a caliper cheap enough to play with but they are all around $100 and up per each. I also need to figure out how to mount them.
Old 05-16-2021, 05:19 AM
