Old 07-31-2020, 04:52 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I got lucky and tightened them and they stopped leaking. They are right on the edge where I worried about stripping the fittings. If I was to do it again I would think real hard about nickel/copper lines.
Thanks! I opted for the banjo fittings from Baer for mine. We'll see when I install it.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 07-31-2020, 06:12 PM
lsuguy's Avatar
lsuguy lsuguy is offline
So the leak was from the banjo hardlines. Where the tubing is brazed to the banjo fitting they didn’t finish the brazing all the way around. I called Baer and they are shipping me a new set.
Old 07-31-2020, 06:59 PM
No from where my lines went to the prop valve. But I had sealing problems with all the stainless lines
Old 08-01-2020, 08:33 AM
lsuguy's Avatar
No I was saying where my leak was at. The Baer hardlines from MC to propotioning valve, one of the fittings was not completely brazed. Explains why I haven’t been able to get any pedal pressure
The Following User Says Thank You to lsuguy For This Useful Post:
waynieZ (08-01-2020)
Old 08-01-2020, 07:07 PM
OK, mine were good there
Old 08-03-2020, 09:53 AM
EVIL SS EVIL SS is offline
killer build. Looks great!
Old 08-07-2020, 08:31 PM
CarlC CarlC is offline
I've fully given up on relying on a good seal when using stainless flares, though I do like the durability aspect. I now use these and have had zero leaks since:
https://www.aircraftspruce.com/catal...37fittings.php
http:www.vaporworx.com
The Following User Says Thank You to CarlC For This Useful Post:
camcojb (08-08-2020)
