Old 09-16-2020, 07:03 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
'm going to say from my experience do not use the top stud type mount for a coilover mount. Mine failed twice, I braced it the second time and if you really think about it was the top shock mount designed to hold the weight of the car? No it wasn't. If you dig hard enough you will find more failures like mine. I repaired it using the BMR coilover mount
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
The Following 3 Users Say Thank You to Jimmy Sean For This Useful Post:
130fe (09-17-2020), anguilla1980 (09-16-2020), dhutton (09-16-2020)
Old 09-17-2020, 07:51 AM
BMR Sales's Avatar
Wow, that is the 1st time I have seen the Tower rip off! I have sold a lot of the Pro Coil setups that use a Stud mount - no one has ever reported this issue.
To me it looks like your Brace started to break and then finally ripped
Old 09-17-2020, 01:32 PM
Jimmy Sean's Avatar
That was the first time it failed. Both sides of the car looked exactly the same. I cleaned it up, welded it back together and added some bracing. Lasted maybe a year, failed again, that is when I decided to use your (BMR) coil-over mount conversion.
Old 09-17-2020, 02:05 PM
BMR Sales's Avatar
What Coilovers did you have and what was the Spring Rate? Is the car a Drag Car that came back down hard?
Old 09-18-2020, 05:02 AM
Jimmy Sean's Avatar
Ridetech HQ single Adjustable. I street drive and autocross my car. I started off with 600# and went up to 800# springs. I put something like 20K miles on the car when it failed the first time.
Old 09-18-2020, 09:21 AM
SSLance's Avatar
SSLance SSLance is offline
Holey cow!!
Lance
