Old 09-15-2020, 02:05 AM
CarlC CarlC is offline
Originally Posted by randy View Post
Fuel pressure question
When you turn the ignition on does the fuel pumps hold fuel rail pressure? Recently installed a lt4 in a friends 69 and ignition on the fuel pressure goes to 40ish and then drops to zero. Tested this with a online -6an fuel pressure gauge at the fuel inlet at the engine. My gmpp ls3 swap it will hold the fuel pressure with key on
What fuel pump is being used and how is it driven?
http:www.vaporworx.com
Old 09-15-2020, 03:15 PM
Stielow's Avatar
Stielow Stielow is offline
Mark,
Leaving cost out of the equation for now, would you ever want to install a full frame chassis in a 1st gen?
What would be your reasons pro or con?
Thanks...
If money were NO concern? I would definitely do a full chassis that was fully designed and engineered. Optimize everything and get the packaging just right. Redesign all the driveline while I was at it. Do all the FEA to make it as light and stiff as possible. Oh and if money were of NO concern I would do a full carbon fiber body to boot.
But then you need to ask your self my favorite Charlie question - "Then what are you gong to do with it".
Cruiser, Track Monster, Both...
At GM we have VTS - (Vehicle Technical Specifications) it has things like:
0-60 times
1/4 mile times
Top Speed
Fuel Economy
Interior Cabin Noise
Wind Noise
Exhaust Tone and Sound Level
Tire Wear
Stopping Distance
Ride Quality
Track Lap Times
Cooling Specs
Towing Capability
Etc.....
Which ones do you want to optimize? We have a teams of people at GM that work for years on this stuff.
You can not have a S-Class Mercedes ride and a Corvette ZR-1 lap times. Hard to violate the laws of physics.
Pro - It would be great! Could spend the time to get a optimized chassis and driveline.
Con - Time and Money, and you will be disappointed when you are done unless you do your own VTS.
Just my two cents.
Mark
Stielow Engineering
The Following 7 Users Say Thank You to Stielow For This Useful Post:
camcojb (09-15-2020), fleetus macmullitz (09-15-2020), kwhizz (09-16-2020), OLDFLM (09-16-2020), redfire69 (09-16-2020), thedugan (09-15-2020), WILWAXU (09-15-2020)
  #523
Old 09-15-2020, 04:35 PM
Stielow's Avatar
Off the shelf Hooker Black Heart header!
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
cpd004 (09-16-2020), fleetus macmullitz (09-15-2020), kwhizz (09-16-2020), syborg tt (09-16-2020), WILWAXU (09-15-2020)
  #524
Old 09-15-2020, 06:57 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Those headers look really good for an off the shelf.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 09-15-2020, 11:06 PM
ARP loves you. Bob's a good friend to have.
The Following 4 Users Say Thank You to camcojb For This Useful Post:
fleetus macmullitz (01-23-2022), Spiffav8 (09-16-2020), Stielow (09-16-2020), syborg tt (09-16-2020)
  #526
Old 09-16-2020, 10:05 PM
randy randy is offline
Carl we have spoken before and I’m sure Rodney has at rods car craft in Wylie Tx. Dual 450 pumps, ricks billet hat, returnless, your lt4 controller splitting the gray wire I think that is twisted in the gmpp harness
Old 09-16-2020, 11:25 PM
So back to the i.r.s question, would you recommend doing a irs "kit' swap using c6 subframe to a 70 A body
Old 09-17-2020, 07:00 PM
jmac jmac is offline
Mark,
I noticed that your rear brake caliper is mounted at the 9 o'clock position, if you were looking at it from the driver's side.
Is there a reason you do this? Any benefit or added performance from the caliper being mounted there instead of the usual 2-3 o'clock position?
Thanks!
My 1967 Camaro
Old 09-18-2020, 04:41 AM
Stielow's Avatar
Nope
Stielow Engineering
Old 09-18-2020, 04:43 AM
Stielow's Avatar
Originally Posted by jmac View Post
Mark,
Thanks!
This is the drivers side
Stielow Engineering
