Old 11-21-2020, 09:27 PM
From a more budget minded perspective, I used the Tanks in unit with a 255lph pump with no problems. Dropping in a more powerful pump is a simple affair, easy afternoon job, and there are a lot of single pumps that will support 750 on gas.
The trade off with a bigger pump is noise, powerful pumps are loud, and you are going to cycle your fuel through the rails a lot quicker if you use a full return system.
The vaporworx system is no doubt the best way to go, but it’s 4-5x the cost of a tanks inc drop in system minimum.
The Following User Says Thank You to MtotheIKEo For This Useful Post:
Rodknock (11-22-2020)
Old 11-22-2020, 01:48 AM
Rodknock's Avatar
Rodknock Rodknock is offline
Thanks for the info
Yeah, for me, swapping the pump is even easier, because I incorporated an access panel into my build.
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
Old 11-22-2020, 12:03 PM
A tanks inc 450 pump module is $340. That will support your hp goal.
+ some kind of regulator (~$150), you are about $500 in ignoring plumbing which will be needed for either option.
Vaporworx module is $430, which just controls the pump.
Not sure what CTS-V fuel pump module assemblies are going for. OEM modules look to be ~$800, aftermarket about the same.
The Tanks Inc tank won't accept an OE style module so you will need to weld in the mounting ring, ~$200 in hardware + installation.
So now you're ~$1500 in. (unless I'm misinterpreting the Vaporworx site)
There is no arguing that the Vaporworx setup is better. Really depends on your intentions with the car as to whether its worth it.
Old 11-22-2020, 04:40 PM
Rodknock's Avatar
The intentions with the car are 99% street/highway driving.
The other 1% will be AutoX and maybe occasional drag strip trips, with max performance in those areas not required. Just be for fun, not competition.
That's why I figured the 450LPH pump will be sufficient obviously, my main concern is whether it will be too much if I opt to run lower power levels initially. Just don't want to purchase two pump if one will do it with proper control.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
Old 11-25-2020, 01:21 PM
pannetron's Avatar
pannetron pannetron is offline
+1 on one of Carl's VaporWorx controllers and a CTS-V pump module. I have that (boost referenced) feeding an E-Force blown 6.2L LS. A step up from that is replacing the GM pumps with DW pumps as another poster mentioned. The GM fuel pump buckets are good.
The Following User Says Thank You to pannetron For This Useful Post:
Rodknock (11-25-2020)
Old 11-26-2020, 12:01 AM
Rodknock's Avatar
UGH!!!
All this new fangled EFI stuff I have to learn. Maybe I shoulda stuck with carbs
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
