Old 12-05-2020, 07:07 AM
Default Driveshaft .. a judgment call.
Pre prerequisite. current power .. 495 Hp and 473 ftLbs torque.
Likley in the future.. magnuson supercharger and cam swap. target 640 ish HP.
Problem.. my 9 inch has a 1310 yoke...
Option 1 just order the 1310 driveshaft it will be fine at 600 Hp/Tq numbers .. Lots of folks are running this says the all might internet..
Option 2 order an 1350 shaft then install a "hybrid joint"
will require a new pinion yoke which may not be the same length and make shaft useless ..
Options 3... change pinion yoke now.. (not sure if on a 9") this-is just a replace or could impact bearing load ect.. and order a 1350 shaft.. now..
Old 12-05-2020, 07:12 AM
Stielow's Avatar
Stielow Stielow is offline
I would call Dynatech driveshafts and ask them. They can run through the numbers and tell you what it needs what if it’ll be strong enough
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
fleet (12-06-2020), XLexusTech (12-05-2020)
Old 12-05-2020, 11:08 AM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Call Mike at Dynamic Drivelines. My custom 3.5" carbon fiber driveshaft was less than $850!!!! It is just him and his wife so he keeps the costs down. He knows his stuff!
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
The Following 9 Users Say Thank You to cjfirstgen For This Useful Post:
130fe (02-15-2021), Che70velle (12-10-2020), fleet (12-06-2020), Goosesdad (12-19-2020), jarhead (12-26-2020), sd67 (12-14-2020), Spiffav8 (12-21-2020), WILWAXU (12-06-2020), XLexusTech (12-05-2020)
Old 12-17-2020, 04:46 PM
Called mike.. super helpful Ordered with him he is making me a 1350 front and hybrid 1350/1310 rear... carbon fiber Driveshaft..
Super helpful and informative..
The Following User Says Thank You to XLexusTech For This Useful Post:
572Camaro (12-17-2020)
Old 12-18-2020, 06:13 AM
cjfirstgen's Avatar
That's great!
Old 12-19-2020, 06:20 AM
randy randy is offline
Thoughts on the driveshaft shop vs dynamic driveshaft? Driveshaft shop balances them to 9000rpms. But it seems dynamic is cheaper as well
