12-11-2020, 04:46 PM
Test Fitting the Radiator (( 08-26-20 ))
Now that the Afco "Direct Fit" Radiator is home and modified so it will work I might as well test fit it.
Cutting up some cheap radiator hose to make make sure I order the correct size hoses.
Next up...drill holes in the Core Support.
Eventually I will drill the holes larger and install "Well Nuts"
Works perfect
Testing a 3" Hose that I borrowed from a friend
Perfect Gap.
12-11-2020, 04:55 PM
Looking good, Marty. Are you going to use pipe and couplings for the coolant hoses? Those glass coolant pipes are cool!
12-11-2020, 05:05 PM
Billet Optima Front Mount Battery Tray. (( 09-07-20 ))
Since I plan to drive this car and really don't want the hassle of having a battery in the trunk. Ron from Wilson Muscle Cars and I designed a factory fit Billet Tray for the battery. Actually it was my idea and Ron drew it up and I had TJ make a few of these.
Since I am running the Anvil Carbon/Fiberglass Inner fenders. I can't use the inner fender to support the battery tray in the front. My solution is to drill a hole in my inner fender and run a support rod up from the Core Support bracket.
Good News...I found something to replace the Chunky Bars.
12-11-2020, 05:18 PM
Wiring, Wiring & more Wiring ((09-07-20 ))
12-17-2020, 01:21 PM
Works perfect
Perfect Gap.
Marty, I'm not sure you'd have enough room for the radiator to 'move' as it heats and cools down with the side to side mounts. You may need some wiggle room there so the radiator doesn't crack somewhere. Maybe take a look on a modern cars cooling system. There should be 'pins' on the radiator that go into usually large grommets. Just a thought.
1971 Firebird
2017 SS
The Following 2 Users Say Thank You to cpd004 For This Useful Post:
12-17-2020, 05:48 PM
Eventually I’m going to be installing 3/4” well nuts on the upper mounts. Do you think that will be enough ??
12-18-2020, 04:22 AM
I'm definitely not an expert. Just had mine leak due to this exact thing. Hopefully someone will chime in that knows more. I think Steilow also mentions it somewhere in his thread.
Maybe contact the radiator manufacturer to get their thoughts?
1971 Firebird
2017 SS
12-18-2020, 07:31 AM
Here is the way AutoRad does it. The bolt cinches down tight on the short shaft collar, squeezes the o-ring a bit (not a lot - it mostly floats in the large hole in the rad), allowing the radiator to be captured but still float. Food for thought.
The Following User Says Thank You to Goosesdad For This Useful Post:
12-18-2020, 10:51 AM
Attachment 73518
Attachment 73519
Here is what I plan to use. (( Well nut to scale ))
12-18-2020, 03:43 PM
So I did a little research and found that a Radiator thermal expansion can be as much as 3mm which should easily be covered by the well nuts in all directions. The well nuts I have are 3/4" so this should allow for plenty of movement.
What's your thoughts guys ?
| Thread Tools |
| Display Modes |
Hybrid Mode
