Old 12-11-2020, 06:23 PM
Rodknock's Avatar
Rodknock Rodknock is offline
Buttoned up the rear suspension stuff, and took the car off the rotisserie, for the last time...maybe
Straightened and cleaned the garage a little. Time to strip the doors to bare metal, and get everything hung, and body worked.
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
The Following 3 Users Say Thank You to Rodknock For This Useful Post:
EVIL SS (12-12-2020), Goosesdad (12-23-2020), syborg tt (12-08-2024)
Old 12-23-2020, 12:15 AM
Rodknock's Avatar
Default Trick Tool Post
This is a pretty neat, but not cheap tool, to figure out wheel size, backspacing, width, etc. Made by a gentleman named Mike Keller, who owns a company named Verified Fabrication. It is a very well made and thought out design. The tires (when I get them) actually mounts to it, and you can move your suspension through it's travel, with wheel turned (up front) and see where you might have clearance issues. I figure a $400 tool is a lot cheaper than $2000 wheels I can't use, if I got the measurements wrong.
This was the only issue I ran in to with the tool. Of course it's not designed necessarily to use with the IRS suspension. I called mike, and he told me the tool is thicker in that area for strength to hold the tire, which is what I thought. So I can roughly take away about 5/8" from the thickness, and it should be good to go with 19" wheels. If I set the slides to 20" wheels it clears, but I don't want 20's and rubber band tires..lol
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
The Following 2 Users Say Thank You to Rodknock For This Useful Post:
camcojb (12-23-2020), syborg tt (12-27-2020)
Old 12-23-2020, 12:33 AM
Rodknock's Avatar
Default Wheel selection!!! Ugh
Wheel selection. Harder to decide than the color I chose!!!
The first pics are the wheel style I initially wanted (not the color), but have since changed. I'm pretty much going to stick with polished outer and brushed centers, but might go with the Royal Gold center (last pic), but not sure yet.
I'M OPEN TO OPINIONS!!!!
Old first choice
New first choice
Second choice
Third choice. I do kinda like the deep dish look though
Color options for the center section
And the Royal Gold color I mentioned earlier, but not this style of wheel
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
Old 12-23-2020, 03:18 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I like the third choice...
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
The Following 2 Users Say Thank You to 214Chevy For This Useful Post:
Goosesdad (12-23-2020), Rodknock (12-25-2020)
Old 12-23-2020, 06:11 PM
Oh, this is hard. Of the three you've posted, I'm with Marcus. The third choice looks best to me. I'm not sold on the spokes coming out to the edge of the wheel. The others also look really difficult to clean, lol.
Color, not gold. Gold against a bright green doesn't look good to me. I'd go a dark gold/bronze or lighter gray rim. I'd suggest a center that's not so dark in color that you lose the details of the machining. Polished lips with machined centers sounds nice. The polished lip helps set off the wheel from the tire and frames the center to me.
Good luck. I hate the idea of picking rims so much that I'd just copy someone else or get something traditional like a Forgeline DE3P or Fiske FM5 or FM10 and call it done. They're not new but they look great. I'd seriously go mad if I had to choose something new.
Old 12-23-2020, 07:19 PM
Ketzer's Avatar
Ketzer Ketzer is offline
All great choices!
I have the first style on my 911. I've been extremely happy with BC and the wheels look incredible in person. I ordered mine in the brushed black and they do have a bronze tint to them...which worked out great on the car.
Jeff-
The Following 2 Users Say Thank You to Ketzer For This Useful Post:
Rodknock (12-25-2020), syborg tt (12-08-2024)
Old 12-24-2020, 07:24 AM
joeko23 joeko23 is offline
They John, I’ve got a similar setup to you. 69 Camaro, Heidts IRS, but I have a chassisworks front subframe. Anyway, I ordered 19x11 wheels with 15mm offset which equates to about 6.5” of backspace. I have no clearance issues. I’m also using a 325-30-19 tire.
Check out some pics of my build. I painted my whole driveline almost a candy red, engine, trans, driveshaft, and the diff housing. Came out amazing! Your doing amazing work too and it’s coming together so quickly!
https://www.pro-touring.com/threads/...d-0-Fab-Skills
The Following 2 Users Say Thank You to joeko23 For This Useful Post:
