Old 12-16-2020, 06:45 AM
68454RS's Avatar
68454RS 68454RS is offline
I would go 325 on a 12 if you have room for a 12" wheel. More choice in 325 as well. 305s for an 11" wheel.
I can't imagine I wouldn't have room for 12's with the DSE mini tub kit, notched frame rail, narrowed rear end, rolled fender lips and Ridetechs triangulated 4 link..
I get the rear back from Moser on Friday so I'll do a lot of measuring and let you know. Thanks
Old 12-29-2020, 01:10 PM
68454RS's Avatar
Resized_20201226_140240 by F G, on Flickr
Old 01-06-2021, 06:43 AM
68454RS's Avatar
Damnitman, even the 325's are giving me fits on fitting.. might have to drop down to a 315/40-18
I don't want to go to a real low pro tire like a 315/30-18
Old 01-06-2021, 07:07 AM
dontlifttoshift's Avatar
What if I told you that a 315/30-18 and a 305/30-19 have the same sidewall height?
You have 14.5" You need .75" to the inside and .25" on the outside assuming you are running some type of link suspension. Those are your minimum clearance numbers. You can run the outside tight as most 67/68 camaros don't travel enough to actually tuck into the fender much anyways.
So your maximum section width is 13.5"
325/30-19 is 13" wide on a 11.5.....put it on a 12 and you get 13.25"ish.
Donny
The Following User Says Thank You to dontlifttoshift For This Useful Post:
68454RS (01-06-2021)
Old 01-06-2021, 08:30 AM
68454RS's Avatar
I'm running the Ridetech triangulated 4 link & coil overs, mini tubs, rolled lips. if .75 and .25 are good clearances then the 325's might just work.
I don't like the low profile of the 315/30-18 or the 305/30-19
I do appreciate your input, Thank you
